Old 09-20-2011, 02:05 AM
Inspiro Inspiro is offline
Rep: 10 Posts: 5
Guide to building 18 foot steel centerconsole
Dear all
I知 new to this forum
I知 an automotive engineer, I live in Egypt, , I love sea fishing in the red sea, and off course boats, but I知 kind of novice in that field with so much to learn
I would love to have my own boat for fishing, a boat that is averagely fast to move quickly from one fishing point to another
In Egypt, fishing boats available for rent are heavy, under powered displacement boats built mostly from relatively cheap wood
Fiberglass boats from well known builders are very expensive and most availiablecdo not take the fishing into account, less expensive pre-owned fishing boats are almost non-existent
So I decided to build my own, I found this forum and I feel that I came to a the best place ever, so many people passionate about boat building and have a wealth of information.
I seek your kind advice based on the following vision I have in mind, please correct me if you see I知 off track:
I知 on a very tight budget,
Center console style
The boat will be used offshore, no shallows at all,
Boat will be used for deep sea fishing, some trolling
Boat is to have room for 3/4 fishermen and tackle
Boat length around 18 feet to be easily towed by a small SUV
wind speeds around 15 knots is normal(waves 3-5 feet of height), boat need to absorb these waves comfortably cruising at 20-25 mph, while being very stable when not in motion, so that we can comfortably fish in these not so ideal wind conditions
Top speed in the high thirties mph is more than enough
Boat will be used 2-3 times/month, mostly towed back and washed after every fishing day.
No live-wells needed
Boat will be equipped with a portable head and portable coolers
Preferred building material is steel (cheapest and easy to find good welders around)
Weight is to be kept to minimum for easy towing, getting into and out of the sea with minimum help, to achieve good performance without need for big power
Outboard engine(preferably not more than 100 hp to minimize cost)
It would be great if you can recommend some boat building steel plans/kits, with proven performance that I can use to achieve my goal
Thanks and best regards
Mahmoud Salem
Old 09-20-2011, 02:18 AM
Mr Efficiency Mr Efficiency is online now
Rep: 246 Posts: 710
Protecting it from rust will be a full-time job, especially as you will be restricted to thin gauge material to keep the weight within reasonable limits, so unless you are vigilant perforations may appear sooner rather than later.
Old 09-20-2011, 04:14 AM
Rep: 10 Posts: 5
Dear Mr. Efficiency
Steel vs Aluminum, a very hot topic discussed hundreds of times
I may eventually switch to Aluminum especially because most of the metal plans for this size is in Aluminum, but this will cost much more in material and labour.
Thanks for your reply
Old 09-20-2011, 04:26 AM
Rep: 246 Posts: 710
18 foot would be at, or below, the lower limit for steel construction, and only because you need a bit of extra thickness above the structural strength requirement to allow for rusting. I guess it is possible if you are prepared to put in the maintenance, and you have a design with no hidden crannies you can't easily access to keep painted. And steel isn't that cheap these days either.
Old 09-20-2011, 05:23 AM
Buoyant Marine's Avatar
Buoyant Marine Buoyant Marine is offline
Naval Architects
Rep: 10 Posts: 2
Originally Posted by Inspiro View Post
Dear all
Mahmoud Salem
Hi Salem,
Your requirement is interesting and workable. We have a database of this size boats which are using for different purposes. We would like to discuss more with your requirement. Kindly forward your contact details to the following email id.
md@buoyantmar.com
Thnks and Regards
Buoyant Marine Services
Old 09-20-2011, 08:50 AM
Rep: 10 Posts: 5
To make it easier, I'm looking at plans for a very capable hull(as I mentioned in rough sea and when stationary), I think a modified V with variable deadrise and wide chines will be good)
I want it as basic as possible(can easily accept something as plain as formosa with non-covered structure rails)
I might consider building from aluminum
Old 09-20-2011, 09:53 AM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Originally Posted by Buoyant Marine View Post
Hi Salem,
md@buoyantmar.com
Thnks and Regards
Reminds me very much of real estate forums, where someone asks a question like "what should I consider in obtaining an adjustable mortgage?" and then someone posts, "For the best adjustable mortgage contact me at XYZ Mortgage Company" .....
Interesting and workable? Of course it is! At least steer him to aluminum for that size of a boat....
Old 09-20-2011, 10:50 AM
Naval Architects
Rep: 10 Posts: 2
Hi Mr. Wavewacker,
I think u misunderstood the case and equate to a real estate forum. Its better if you could help him rather than talking about Mortgage Companies..
New steel outrigger 80 foot long 2buildboat Multihulls 3 09-13-2010 03:30 PM
Building a study guide before building Luckless Boat Design 17 12-29-2009 09:35 PM
40 foot steel board JamesH Boat Design 0 10-05-2005 02:33 PM
ABS Guide for Building and Classing High Speed Craft Boa Boat Design 2 10-30-2004 05:24 AM
ABS Guide for Building Racing Yachts, Sandwich Divisor Boat Design 0 04-04-2003 05:30 PM
