Old 05-29-2008, 05:20 AM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Great new thermal insulation for Boats?
http://therma-green.com/technicals.html
Old 05-29-2008, 05:30 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Hmmm - looks good but no prices - always a worry!
Old 05-29-2008, 05:40 AM
imagineer
Rep: 58 Posts: 436
There are prices on the web site and they are quite reasonable considering the benefits of light weight, easy application and corrosion-proofing. You get to this page by clicking on the click here to purchase button on the products page.
Quantities desired for 1 gallon and 5 gallons pails can be adjusted in the shopping cart.
Liquid Insulation and Corrosion Protection. For Pipes, Tanks, Metallic Surfaces. -40F-257F (-40C-125C)
$69.95 / 1-gallon pail
$349.75 / 5-gallon pail
Liquid Insulation and Mold Protection. For Non-Metallic Surfaces. -40F-257F (-40C-125C)
NSF Registered
Liquid Insulation and Corrosion Protection. For High Heat applications. -40F-400F (-40C-204C)
$79.95 / 1-gallon pail
$399.75 / 5-gallon pail
Liquid Insulation and Mold Protection. For Interior and Exterior Applications. -40F-257F (-40C-125C)
$65.95 / 1-gallon pail
$329.75 / 5-gallon pail
Liquid Insulation and Mold Protection. For Interior Applications. Can be tinted. -40F-350F (-40C-177C)
Lead Encapsulation Coating. Clear coating for encapsulation of lead based paint.
$74.95 / 1-gallon pail
$374.75 / 5-gallon pail
Automotive Parts Coating to reduce heat transfer and increase fuel efficiency. -40F-400F (-40C-204C)
$25.95 / 1-quart
Quality white, semi-gloss top coat for use with Nansulate® Coatings . -40F-350F (-40C-177C)
$56.95 / 1-gallon pail
$284.75 / 5-gallon pail
Quality white, primer . -40F-350F (-40C-177C)
$45.95 / 1-gallon pail
$229.75 / 5-gallon pail
Old 05-29-2008, 06:01 AM
Rep: 756 Posts: 3,328
And always the hard question , how well does it burn?
FF
Old 05-29-2008, 06:12 AM
imagineer
Rep: 58 Posts: 436
How well do any foams burn? Do they protect against mildew? And with only a 3 mil film required, there is much less to burn!
CURRENT SOLUTIONS
By Industry:
  • Oil & Gas
  • Petrochemical
  • Marine
  • Pulp & Paper
  • Automotive
  • Industrial
  • Pharmaceutical
  • Original Equipment Manufacturer
  • Construction
  • Ship Building
  • Home Owner
By Application:
  • Pipe Insulation
  • Tank Insulation
  • Pipeline Insulation
  • Attic Insulation
  • High Heat Applications
  • Protective Coating
  • Corrosion Prevention
  • CUI (Corrosion Under Insulation) Prevention
  • Home Insulation
  • Duct Insulation
  • Energy Savings
NANSULATE®, patented technology, is a revolutionary breakthrough in the science of thermal insulation. Nansulate® liquid applied insulation and rust inhibitor is a premium industrial grade rust proofing protective coating containing Hydro-NM-Oxide, which is documented the best insulating material on the planet...by far (thermal insulation comparison). When fully cured, Nansulate® contains approximately 70% Hydo-NM-Oxide and 30% acrylic resin and performance additives. It has unique and astounding thermal insulation and rust inhibitor properties which surpass all other forms of insulation previously available. You now have the opportunity to use Nansulate®: Technologically advanced protective insulation and corrosion protection that provides superior solutions to your insulation needs and offers energy savings for your home or business.
Features:
  • Outstanding corrosion prevention and insulation properties
  • Easy Application with brush, roller or airless sprayer.
  • Non-toxic, water-based
  • Color: Translucent finish, with White Top Coat also available.
  • Allows for visual inspection of the substrate through the coating
  • It exhibits outstanding durability with excellent adhesion to steel, aluminum, galvanized aluminum, fiberglass, pvc, wood, concrete, plastic, and many more substrates.
  • Does not contain any potentially harmful anti-microbial additives or biocides
  • Resistant to existing molds as well as resistant to new molds
  • Cost Effective Product - Long Term Savings
  • Spread Rate 150-175 Sq. Ft. per gallon with a three-coat coverage, varies depending on surface porosity and texture.
Benefits:
  • Protects Against Corrosion Under Insulation (CUI)
  • Excels in Providing Thermal Insulation in a Thin Layer
  • Resists Mold and Moisture
  • Space Saving – each coat is applied at 3-5 wet mils; a full three-coat application will dry to 4.5-7.5 dry mils.
  • Easy Cleanup – soap and water
  • Can be painted over
  • Low Installation Cost
  • Helps prevent burns
  • Prevents rust
  • Ideal pipe insulation and industrial coating
  • High temperature environments – up to 400F (204C) for our High Heat formula.
  • Do it yourself – easily applied by maintenance crews or individuals.
  • Equally suited for Industrial and Home Insulation Use.
  • Energy Savings - a cost effective way to save money and lower fuel bills.
Old 05-29-2008, 06:17 AM
ASM ASM is offline
Rep: 56 Posts: 131
Fred
We frequently subscribe Delta T as a thermal and anti-corrosion coating for the luxury yacht industry. See www.mascoat.com for additional information, they have certificates from a lot of maritime insurance companies (Lloyds', DNV, MCA, etc.)
Another one would be Noxudol, http://www.noxudolusa.com/
All are thin coatings.
Old 05-29-2008, 06:22 AM
imagineer
Rep: 58 Posts: 436
Actually a 3 coat, 7.5 mil film is required. Another advantage is that it is clear. You can paint corrosive materials and still see any signs of corrosion under the film. There is also a high heat version.
Old 05-29-2008, 06:51 AM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Don't get too excited
The data given by the company at Jonathan's first link tell an interesting story. The company shows a thermal conductivity for their material of 0.017 W/mK, and for Polyurethane Foam of 0.040 W/mk. These data give a nice thermal conductivity ratio of 17:40, or to put it another way their material is only 42.5% as conductive as the Poly Foam.
This is a painted or sprayed-on coating, however, so you are talking about very thin applications. But anyone who has looked at insulation for their house knows that a thicker thermal insulator works much better than a thin one. I doubt that the relationship is actually linear, but assuming it is for a first approximation, then two inches of Poly would have twice the insulating properties as one inch. Applying this principle to this Therma-green material, then you would have to paint it on almost a half inch thick (0.42 inches) to just equal the thermal conductivity of one inch of Polyurethane foam.
Furthermore, the Polyurethane foam was the WORST material listed at the web site cited.
All of which makes me think that the best approach is a good paint seal on the inside of the hull (epoxy or urethane) followed by a synthetic rubber based closed-cell foam either glued in place or mechanically held in place. The latter is less likely to trap moisture, but the former is less likely to let that moisture in in the first place.
Old 05-29-2008, 08:07 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Interesting, but how much is true and useful after the fine print is understood?
The best insulating material? Maybe, but the best insulator yet discovered is a vacuum. Glacier Bay exploits this kind of insulation but it is very expensive.
I experimented a few years ago with making my own vacuum material. I took a 1" thick sheet some very porus foam, put it in a plastic bag and poured in some epoxy thinned with a lot of acetone. Had to see that the foam was not eaten by the acetone first of course. The foam was squeezed around to make the thin epoxy penetrate, taken out of the bag and squeezed as dry as possible.
After it cured, I tested the compression resistance and found that it would easily withstand atmospheric pressure. What was left was to seal it in a metalized plastic bag and evacuate the envelope. That has not been done but I did cut the foam apart and found that the epoxy only penetrated a little over halfway to the center from all edges. A better infusion method would take care of this.
I am convinced that one can make their own very high R value insulation this way and it will probably be better than all but the more carefully controlled Glacier bay material. The plastic bag is the same material used on potato chips and other foodstuffs sealed for preservation. It would be tripled heat sealed on the edges which my calculations show would be the weak point for air leakage. The metal film also acts as a radiation barrier.
Tom Lathrop
Impluse heat sealer for thermal urethane kach22i Sailboats 5 02-01-2008 04:29 PM
Great sail, great gale, a little carnage and lessons learned CharlieCobra Open Discussion: All Things Boats & Boating 9 11-20-2007 12:49 PM
RIB - Impluse heat sealer for thermal urethane kach22i Boatbuilding 6 10-11-2007 03:41 PM
Thermal spray coatings & antifouling on steel yachts SeaSpark Metal Boat Building 1 08-19-2006 07:39 PM
Great site here with great stuff... Gbenz Open Discussion: All Things Boats & Boating 7 07-18-2006 10:07 PM
