  #46
Old 01-28-2009, 12:25 PM
venomousbird's Avatar
venomousbird venomousbird is offline
Rep: 29 Posts: 84
Originally Posted by Village_Idiot View Post
You need RANDOM PROTRUSIONS on the surface, to break up the eddies before they get too large to disturb laminar flow. See my earlier post. I suspect the protrusions need to be large enough to be rather unsightly.
Barnacles for example. . . ? Just kidding!
Maybe the idea of dimples on a sail could be investigated?
  #47
Old 01-31-2009, 04:44 PM
speedboats's Avatar
speedboats speedboats is offline
Rep: 124 Posts: 117
From what I'm reading you're suggesting dimples (or pimples) on a sail or displacment vessel? What of a planning craft. I've often been asked and given a similar response to what was aforementioned, but the thought of aerating the water under the hull to reduce surface friction is what we try hard to achieve, only it has to be controlled and uniform (symetrically). Has anyone experimented of have thoughts on weather the dimples would trap air at say above 60mph, or turbulate enough to reduce surface tension of the water on the hull? Of would this just increase the nett drag?
  #48
Old 01-31-2009, 05:06 PM
Rep: 29 Posts: 84
I was wondering what effect the flow of air under the boat would have myself.
  #49
Old 01-31-2009, 08:44 PM
speedboats's Avatar
Rep: 124 Posts: 117
alot of the so-called 'tunnel' boats are trying to capitalise in the 'wings-in-ground-effect' concept. I have routed exhaust under the hull bottom. Not sure of the benifits (although the boat vibrated and reverberated oddly at non-planning speeds), 'cause if we traveled in anything but a straight line the jet pump would suck air and cavitate, hence we changed to a through-transom exhaust quick smart. Perhaps this'll work in a 'stepped' type arrangement. But 'drizzling' small air bubbles under the hull makes sense on paper, would dimples under the hull help trap these and in effect reduce the friction coefficent
  #50
Old 12-22-2010, 01:55 AM
Pakal's Avatar
Pakal Pakal is offline
Good morning everyone - i remembered this discussion last night and i thought i could give you an update about an actual boat that is already on sale in Greece.The manufacturer is AirHull SA and you can find interesting photos and videos on their web site, www.airhull.com .
  #51
Old 12-22-2010, 02:15 AM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Originally Posted by speedboats View Post
...but the thought of aerating the water under the hull to reduce surface friction is what we try hard to achieve, only it has to be controlled and uniform (symetrically). Has anyone experimented of have thoughts on weather the dimples would trap air at say above 60mph, or turbulate enough to reduce surface tension of the water on the hull? Of would this just increase the nett drag?
I wonder if you could use small strakes near the bow to create cavitation in the water and hence bubbles. I'm thinking something like vortex generators on aircraft.
  #52
Old 12-22-2010, 03:06 AM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 710
I'd be interested to hear the opinions of the folk here about the concept illustrated in Fig. 3 on this site.........
http://docs.hydrofoils.org/SAS03.pdf
  #53
Old 12-22-2010, 04:22 AM
Joakim Joakim is offline
Rep: 321 Posts: 409
I guess that would only work for high displacement and/or low speed hulls. Otherwise air will leak out when you trim up to shorten LWL.
Are there any papers showing the claimed reduction of drag? Did they take different trims into account?
  #54
Old 12-22-2010, 09:59 AM
claydog claydog is offline
Rep: 37 Posts: 41
Interesting thread, just to toss out a little food for thought, On the TV show Mythbusters they did a test on whether a dimpled car would get better MPG. they covered a car with about an inch of modeling clay, ran the car on a closed course to get a MPG figure. Then they cut dimples( about 1/2 " deep and 4" in dia.) in the clay all over the car puting the removed clay in the car to keep the weight constant and ran the same course at the same speed and got a significant improvement.
  #55
Old 12-22-2010, 11:43 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
This topic is an extention of Golf Ball Fluid Dynamics TS Inquisitor 11/28/2005
  #56
Old 12-22-2010, 06:32 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
There is already a product on the markey to dimple your car, but the results arent that straight forward
http://ecomodder.com/forum/showthrea...aims-8321.html
It would be interesting to know what speeds the mythbusters went in their tests. certainly, at consistant high speeds, dimples create more drag from what I can remember. The dimple effect has been examined for over a hundred years, so one would think that what isnt dimpled, shouldnt be ???
  #57
Old 12-22-2010, 06:37 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Originally Posted by Pakal View Post
Cool.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
  #58
Old 12-22-2010, 06:53 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
So if your car has been in a hailstorm it should go faster?
Hoyt
How to Install Boat Windows and Port Lights TCP Bob Boatbuilding 0 01-20-2007 02:23 AM
Golf Ball Fluid Dynamics Inquisitor Boat Design 64 12-11-2006 07:15 AM
Ya'know, like a golf ball resurrected Boat Design 27 11-09-2006 09:22 AM
Which Jacuzzi to install in my Boat? the big jetski Propulsion 4 12-14-2005 03:46 AM
Boat Ball GordMay Boat Design 0 01-17-2004 07:02 AM
