Old 08-03-2004, 12:27 AM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
Glass Bottom Boats
Can anyone give me any advice on glass partitions installed in the bottom of a boat. What I'm looking for is glass types and thicknesses, bottom rigidity requirements, sealing, installation methods, personal experiences, pros, cons, web sites, etc. ANY information at all would be useful.
Thanx Large, Joey
Old 08-10-2004, 09:28 PM
larry v larry v is offline
Rep: 10 Posts: 9
glass bottoms
Most use lexan. Any thing over 1/2 inch is concidered bullet resistant. seal it with butial calk. The thickness depends on how big your window is.
hope this helps
Old 08-11-2004, 02:52 AM
foxxaero foxxaero is offline
Registered
Rep: 14 Posts: 69
glass-bottom fiberglass boat
Hi Joey - I agree with Larry. here's a pic of a glass-bottom boat ...
http://www.fiberglassics.com/forms/f...&messageID=892
Cheers
Russ
Old 08-11-2004, 03:03 AM
Registered
Rep: 14 Posts: 69
Here is Russian design concept ...
http://www.paritetboat.com/ellips.shtml
Old 08-11-2004, 04:19 AM
Rep: 66 Posts: 640
Joey,
Lexan is good for the impact resistance, but does not subsistude for bottom strenght. So, the window frame should be reinforced, how much depends on the size. Sealing can be done with Sika or similar. And I'd think of ways to save your skin when a window springs a leak (blinds, inflatable seals, anything).
Good luck,
Peter
Old 08-20-2004, 01:00 AM
Member
Rep: 10 Posts: 107
Thanx guys, Good info
Glass I'm considering is 1" thick bullet-resistant.
Old 08-20-2004, 03:27 AM
Rep: 66 Posts: 640
Arrow,
Informative: How thick for window glass
The formula for glass thickness can, in principal, also be used in your case, just adjust the design pressure.
About Flat Bottom Boats.....? jfnewell1965 Powerboats 9 12-05-2005 11:03 AM
Prices of used boats, US vs UK... Aquatek Open Discussion: All Things Boats & Boating 3 09-05-2005 06:57 PM
UK - Fibre Glass Workers Required MnM Int. Services & Employment 1 07-07-2004 10:42 AM
Glass boats survived isabel stainglassboats Marketplace 0 09-23-2003 07:20 PM
