| Thanks all. It was just a thought experiment. My design was an 8' sphere within a slightly larger spher with well oiled bearings. This is the main cabin of a small catamaran. Like this: ![]() Imagine a sphere within that cabin. The captains weight on the bottom would be the ballast of the sphere and the boat itself would rotate around it. Even capsized, i would still be sitting upright insted of being flung to the ceiling. Like i said, just messing around with the idea. Didnt realise it would have its own momentum. I wonder if there is a point where ballast is heavy enough to keep the inner sphere level? |
| It is certainly possible but hugely challenging. Dampening would be the key. -Tom |
| ten foot long or ten foot wide? I have to ask. |
| Get a hammock ![]() |
| I think you should look at the modern washing machines. Instead of spinning they slosh back and forth in a powered motion. If you use some electronics to sense vertical, you could design a control system which drove the "sloshing" motor to keep the cabin vertical. Might be pretty expensive for the redesign, and I don't know that you could get the reaction time fast enough to not be out of sync and act like the ballasted examples above. Actually, I think if you dislike the motion so much you should get a bigger boat or a bicycle. ![]() Quote:
| Sorry, I guess I should not have been so negative, I suppose this will get deleted like the last time I got sarcastic. Thought police are everywhere. |
| just a few days ago there was the same proposal....I think you'd be better off thinking bigger first of all because it will take some hardware and breaking mechanisims to control and slow the rotation, which mean more weight. The gimbal contraption will have an x and y axis, a ring around the cabin on one and that ring on another axis 90 degrees. Each axel will need a locking brake to keep it somewhat in the position desired and released as needed. The axels could also run in to a something like a rotary engine with fluid and ports allowing the fluid the be pushed out of one port and in to a reserve that would be replaced in the rotor, slowing the rotation of the axel or stopping it. It could be electrically controlled to a mechanical method. Perhaps magnetically. Investigate targeting systems on a tank. Something strong enough to mount a cabin to will need to be pretty stout to take the abuse, so I would think it would need to be out of steel (or some very expensive materials keeping weight down, like cabon fiber) but on the cheap, steel. The mechanisim will also need to be heavy duty as well, more steel. All this could weigh between 500 to 1,000+ pounds. So, you just turned Miss Cindy into a submarine. Instead, why don't you figure out how to allow a catamaran to be connected fore and aft so that the hulls can rotate if capsized and allow the frame members to remain upside down. Anyway, what ever you power it with would need to be on a wire or remotely. Are you going to have your motor mounts rotate as well? Maybe the easiest way is to build a cat with a high clearance bridge deck and hang a hammick (sp?) between the hulls! Use some bungee cords off the sides to keep yourself from banging in to the hulls.... ![]() |
Imagine a cat with two symetrical hulls that work the same when capsized. So regardless of which way is up, it is the same boat. Obviously you cant use a mast and sail as it will be under water. But use a kite on a swivel. So the cat can roll completely and the cabin is always level. That way you can have the speed of cats without the (cats are too easy to capsize and too hard to upright comments). ![]() |
| Stonedpirate Have you seen this thread? Gyroscopic Multi-Hull Design Similar ideas, just as bad. Have you ever sailed a cat? Cats are not EASY to roll. Just put up a trivial amount of sail and go as slow as a monohull. The other trick is to make them very wide, also. There have been some production boats that used a weighted centerboard or daggerboard. They didn't last long in the market. |
#25
| Jeremy, your mistake with the bed was keep it at low level. I suspended a bed up high, loft style, on about 40" wires. Worked fine, and I had a nice sprawling desk underneath. The "bed" was just 1 1/8" plywood 4' x 8' sheet with 2x6 on edge down the middle underneath. The wires werent straight down but a traziod one 16" OC joist wider, so 8" on each end (and on sides) and it would very much 'find level' and only move a little. |
#26
#27
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| airstream for a cabin, weight of conventional aluminum cabin | adamanderr | Materials | 4 | 07-29-2010 06:37 AM |
| Assembly of an Alpha sterndrive to the Gimbal. | Mark Emaus | Sterndrives | 3 | 07-27-2010 02:47 PM |
| Gimbal Housing | Mark Emaus | Sterndrives | 5 | 09-27-2009 10:26 PM |
| volvo 8.2 DP-SM gimbal bearing | ktm123 | Sterndrives | 1 | 03-16-2009 07:22 PM |
| 18-24' Cabin / Half cabin moulds | Louis | Boat Molds | 0 | 07-27-2005 03:48 AM |
