| Getting a pocket cruiser to sail well I am considering building a small pocket cruiser of around 18'/5.5m LOL out of fiberglass/epoxy reinforced plywood. I have read that small boats has a tendency to nose dive. I would assume that this can be compensated by a narrow hull form towards the stern. I wanted to check the LCF/LCB at different heel angles with the excellent FreeShip but it does not seem to support such a feature. Am I on the wrong track? Most small pocket cruisers I seen has a very wide stern which seem to contradict the problem with nose diving. Since a large boat (such as V70) cannot be scaled down and keep its characteristics, that's not a option either. Does anyone know about a well sailing pocket cruiser that is more optimised to sailing well than for e.g. space and wich can give me a hint on the hull form needed. For stability I was thinking of a keel with keel bomb (150-200 kg/300-500 lbs). Is it possible to make it retractable for e.g transportation and landings? Can such a pocket cruiser plane (Assuming a displacement of less than 1 tonnes)? In suche case, how big sail area would be needed? I am a novis but trying to learn... Cheers |
| Boats that pitchpole(nose dive) do so because of a variety of reasons. Among them is poor design and bad handling.
__________________ Gonzo |
| Have a look at this site on a very nice looking 19 ft. cruiser/racer in strip planking. http://www.nautikit.com/Idea19.htm |
| If performance you want, you could build a Dudley Dix Mini 6.5. Huge rear end and fast like a bullet. If you are going to cruise, they have a cruising design. |
| Thanks for the good links and references. I'll probably will try to make a similar keel handling as Idea19. Cheers |
| Pocket cruisers | Guillermo | Powerboats | 322 | 09-28-2009 08:28 PM |
| take a look at this new pocket racer | mistral | Sailboats | 7 | 07-31-2006 08:35 AM |
| Suggestions on hull scantlings for pocket cruiser? | RWL | Boat Design | 10 | 03-30-2005 09:57 AM |
| decommisioned sail boat as a displacement cruiser? | rickc | Powerboats | 0 | 10-21-2003 10:44 AM |
| Pocket Cruiser | qadeer | Boatbuilding | 1 | 07-08-2002 04:05 PM |
