Old 03-01-2008, 08:31 PM
K-36-canvasback K-36-canvasback is offline
canvasback
Rep: 10 Posts: 4
gelcoat substitutes
I am preparing to make a part in a mold.the mold surface is regular gelcoat & will be waxed with mold release.The part will be fiberglass hand laid into epoxy resin.I would like to know if there are other options for the colour coat.perhaps a two part polyurathane.am concerned that the epoxy wont bond to it or even if epoxy will bond to a polyester gelcoat.Anybody have experience with this?
Old 03-02-2008, 02:55 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
You can bond epoxy to polyester quite well, not the other waty around.
Epoxy over a poly gelcoat is quite OK.
Old 03-02-2008, 02:02 PM
canvasback
Rep: 10 Posts: 4
Any idea about using Awlgrip or Endura for this same purpose.I was wondering if these two parters will lay onto the waxed mould or if there would be a negative reaction to the mould release.Also will the epoxy then bond to it without sanding?
Old 03-02-2008, 05:24 PM
Landlubber's Avatar
Mate, you have no hope on earth of syraying a twp pack linear ployurethane paint onto a waxed mould.
It will fisheye like you have never seen.
Stick with the gelcoat, it is heap and good, and then paint the product upon release if you must.
Old 03-02-2008, 10:38 PM
canvasback
Rep: 10 Posts: 4
Landlubber..Thanks for the info.I was wondering about the fisheye thing.Trial and error can get expensive!
Old 03-03-2008, 08:43 AM
GG's Avatar
GG GG is offline
offshore artie
Rep: -30 Posts: 190
there is a product that is sprayed over jelcoat while it is in the mold & it is called POLYBOND . Douglas Marine /Skater uses this product , because they experienced bond issues with jelcoat on there ( epoxy ) parts G.G.
gelcoat help? SCUBAnut Materials 7 01-11-2007 08:29 PM
Gelcoat help pappastratos Boat Design 0 06-19-2006 11:02 PM
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 10:09 PM
gelcoat Jorge Wooden Boat Building and Restoration 8 08-25-2005 06:24 PM
Tyvek coverall or substitutes Gilmarine Marketplace 0 09-21-2004 10:02 AM
