Old 05-31-2008, 11:13 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1474 Posts: 1,620
Gaff Cat pt2
This has taken quite a bit of time
however it was certainly worth the huge effort
most definately two escape hatches
thanks guys - they drew out fine (boat upside down)
i am busy tidying up the cad
will start posting clear drawings soon
Old 06-01-2008, 03:01 AM
Manie B's Avatar
hi guys will you please see if you can open the following
the side view should open in Rhino and Turbocad
the Delftship hopefully should also open in Delftship
i am hoping to get a clearer picture out there for general comment as i go along
these are the things i am "tweaking" at the moment to ensure that everything "matches" with the "parameters"
still a lot of work to go
i am finalising the architectural design at present = galley up - and fresh water below for ballast
Old 06-01-2008, 03:03 AM
Manie B's Avatar
this is it
Old 06-01-2008, 03:09 AM
Manie B's Avatar
delftship opens easy
dxf i save to Rhino
open Rhino and open dxf CAD Gaffcat side
make sense???
Gaff rigs Manie B Boat Design 40 06-23-2008 04:08 PM
Mini Gaff Naked Dave Wooden Boat Building and Restoration 0 06-02-2005 11:16 AM
Help with gaff cutter design dwak Boat Design 3 01-02-2005 03:27 PM
gaff rig design Guest Boat Design 4 08-04-2003 10:09 AM
gaff schooner ongolo Boat Design 0 07-30-2003 03:45 PM
