| @Alan White: Perfect! This is exactly the kind of info that I was hoping to get. ![]() I'm glad to hear that I'm not the only one here who likes the looks and lines of those oldie nutshells. ![]() Do you have some pics of your boat to show? |
| I should have some pictures. Gotta go now, but I'll post a couple later. |
| Daiquiri, I'm interested in what you had in mind for mixed stitch an glue construction. Attached is a sketch of a craft I drew specifically to explore such a build before trying it on a bigger boat. I wanted to figure out how to build heavyish stitch and glue style craft single handed. Came up with the idea of joining five stitch and glue panel pairs and assembling them on frames. Each component light enough to be handled by one person easily. The round bilge gets strip-planked last. The five panel pairs are the hull bottom, port and starboard fordeck/topsides, and port and starboard aft deck/topsides. king planks join deck centers. Butt blocks join Fore and aft. Seems easy to pattern and kit if the build method works. The test boat- a 21' Hampden type. Sorry the second image is inverted, I can't flip it and save it with my software. |
It might also allow you to pre-assemblate and install all the interior joinery and plumbing before enclosing everything with fore and aft modules. It should make the cabinetmaking faster and much more comfortable. The problem again is that it requires a very precise job, in order to make all the modules fit well. My idea was different... It was driven by the necessity to have a reinforced keel, so that I can insert properly shaped lead bricks into the cavity formed by the side plates. So I was thinking about making the boat's bottom (keel plus first row of port and starboard strakes) with ply-on-frame method, while the upper strakes would be added with stitch and glue technique. The frames would therefore extend vertically only till just above the first chine, and would act as a support for the floor grating. All above that would be essentially clear from frames - though I will know that only after I've performed proper scantlings. Apart the area around the mast, which will be generously reinforced, of course. P.S. It's been quite a while since the last time I saw drawings entirely made by hand. I find it very proper for boats of this type. ![]() |
| Terminating the frame ends as you described is tricky. both the frames and the hull are very rigid entities and there will be a great concentration of stress at the nib ends. For a boat like you've described, I would cut a 4", 5", and 6" square of 5 oz dynel and epoxy them over each nib, small to large. Works for me. I'm guessing frames from 12mm ply and a skin of 7-9mm stuff?. I should probably mention I tend to build things as if they will survive forever. I managed to crack two rib ends on one of my boats when it fell four feet onto concrete. The cracks showed up two years later. |
| I would recommend drawing your sailplan first and then configure the keel to balance it. Perhaps everyone is assuming that, but I don't recall that anyone mentioned it. |
| modeling full keel hulls | turnbuckle | Software | 3 | 05-20-2009 04:14 PM |
| Adjusting lead ballast in a full keel | dhornsey | Sailboats | 10 | 01-22-2009 04:04 AM |
| Keel : Rudder Length | Alixander Beck | Sailboats | 54 | 11-30-2005 09:42 PM |
| Affixing full keel to canoe body | RDB | Boat Design | 0 | 05-17-2004 05:58 PM |
| modeling full keel hulls in rhino | Kirk Hill | Software | 12 | 11-17-2003 06:58 PM |
