| I am sure you are correct. BUT. My boat and Capt. Chris's are one of a kind, being done by the seat of our pants, by do it ourselves. In the height department, we know our boats are going to float like corks, due to the much lighter new engines. We will both probably double tank capacity around the COB. If you have to add weight, make it usefull. |
![]() the calculation is quite elementary. you take for instance in this case 60" times 48" that equals 2,880 square inches for the top and bottom each then you times that by 2 that equals 5,760 square inches. Then you take your hight of 20" times the length of 60" wich equals 1,200 square inches each side multiply by 2 wich equals 2,400 square inches. Finaly you take the height of 20" once again and mutiply the 20" by the width of 48" wich equals 960 Square inches then again you multply by 2 and get 1,920" total for the width sides and add the 3 #s together to get 10,080 SQ. inches total! take the grand total and multiply by .0187 (the square inch weight of 3/16" thick aluminum distributer standard means of calculation of metal weight and pricing!) and you get an acurate 188.496 lbs. I also doubt that there are any baffles in this small of a tank and really doubt that any liquid at any speed that this boat is cabable of will ever burst a weld on a 3/16" tank! sorry just my .o2 I really like things as simple as posible thats all different strokes for different folksQ ![]() |
Good luck with your project!
__________________ if yah fly outa that boat tuck-n-roll if yah can :devil: !! http://www.weismann.net/MKII.gif |
| I would love to use a model. But I can't afford her. ![]() |
| Thanks again for the info!!!! It's nice to be able to bounce this stuff of guys that actually know what I'm talking about! My buddies here just keep asking if it's finished yet and when can we go fishing(they have no conseption!!). I'm still working on get all my numbers together. I am trying to get the stringers all glasses in next week so the under deck gear can be laid out. Thanks!! Chris ![]() |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| sealing up fuel tank fittings | ducaes | Boatbuilding | 4 | 06-01-2005 03:37 PM |
| FRP Fuel Tank Fittings? | Fixin2 | Fiberglass and Composite Boat Building | 1 | 03-04-2005 02:45 PM |
| Fuel tank inquiries. | Hou-Chap | Fiberglass and Composite Boat Building | 5 | 03-04-2005 09:02 AM |
| Fuel Tank Setup | Hiptrip | Boatbuilding | 7 | 06-10-2003 09:26 AM |
