Old 09-14-2012, 05:02 PM
Slimjim Slimjim is offline
Rep: 10 Posts: 3
Fuel Consumption of Larger Yachts
Hi to all and thanks from a lurker.
I'm thinking of getting a larger motoryacht to live aboard,as the values of the 10-15 year old yachts have really dropped with the meltdown and what not.
I have ocean front property,so docking is no problem.
I have looked and emailed brokers,but can't find any info on consumption at lower speeds-it's not so much the amount as we will use it rarely- just need to know what kind of range I may expect for a 75-85' yacht like a Sunseeker.
Any hints will help and thanks again.
Jim
Old 09-14-2012, 09:34 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 574 Posts: 1,036
Hi slim and welcome to the board.
I've had those thoughts lately too..the prices have dropped,and any on the market have been so for years..so the owners need to get realistic.
I have a small oceanfront cabin up the coast-but docking in front of it is not a good thing and as you know docking anywhere near Vancouver for something that big is very hard and $$$$$. Otherwise I'd be so tempted.
Anyways,I was on a charter Sunseeker 84 Manhattan.
Almost all of them came with the 1400hp Cat 3412-which is not a too desirable state of affairs.
If they've been used to any of the hp potential they tend to have problem$$.
Or when..and I mean "when" not "if" one of them drops a valve,a liner fails,a skirt breaks,or the aftercooler leaks and breaks your pistons-pull it out and throw in a reman Cummins QSB11 as the main driver.
Anyways I remember at 10 knots/1000 rpm both engines/ it was 90 litres an hour.
I don't see why not at 7-8 knots, you'd be down to 50-60 litres an hour.
You'd want to open them up a couple minutes every hour.
At 22 knots it's 400+ litres an hour.
Look into Fairline,Princess/Viking-the Italian boats seem to be more expensive.
Old 09-15-2012, 07:03 AM
TANSL TANSL is offline
Rep: 119 Posts: 475
Search with Google catalogs of engine manufacturer. They indicate consumption, generally, in grams / hp-hour. (about 200 gr/hp-h)
They do not say that consumption occurs under ideal navigation conditions, with the engine at 80%, but is data that can be used with caution.
See attached example.
Old 09-15-2012, 01:42 PM
WestVanHan's Avatar
Trying to be helpful tansl, but without knowing how much hp it takes to move the yacht at a speed-charts and specs are useless.
Old 09-15-2012, 02:41 PM
Rep: 119 Posts: 475
Well, you tell me how you will meet the consumption?. Or do you think that yachts consume according to their length?
B.R.
Old 09-15-2012, 02:57 PM
Tad's Avatar
Tad Tad is offline
Boat Designer
Rep: 2143 Posts: 1,925
Princess V72
C32 Cats
1000 RPM = 11.3 knots and 40gph = range of 295 miles
Sunseeker 70
1550 HP MANs
1000 RPM =10 knots and 23gph = 500 miles range
1250 RPM = 11 knots and 42.5gph = 300 miles range
1500 RPM = 18.3 knots and 51gph = 399 miles range (best mpg)
Those are US gallons
Old 09-15-2012, 03:13 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 213 Posts: 794
not to thread jack, but how about two engines on one shaft, so.....
you aren't lugging a big diesel at lower speed, but still got full power with both engines running.
Ideally, I'd have 6 and 12 cyl engines, so I'd have 3 possible power levels....6, 12 or 18 cyls.
Old 09-15-2012, 03:29 PM
Rep: 575 Posts: 1,929
If you have to ask... You cant afford it. Owning a big yacht is not about fuel, everything else is expensive too. Keep it below 50' and you will save tons of money.
Old 09-15-2012, 03:59 PM
Tad's Avatar
Tad Tad is offline
Boat Designer
The question concerns range, not consumption.
Old 09-15-2012, 05:10 PM
WestVanHan's Avatar
B.R.
tansl...read my first post-I already answered his question.
He wants to know a rough idea of actual consumption,not charts to be used '"with caution"
"Or do you think that yachts consume according" only to their engines?
So you see,the figures that Tad was kind enough to post are quite close to what I posted...and I've said before,the big semi-d yachts get surprising fuel economy when throttled back.
UR right squid..if I could find one with rotten engines for cheap,I'd throw in QSM11s and be happy to toodle around at 8 knots and with whatever top speed I got.
100+ US gallons an hour at speed doesn't sit right with me.
Old 09-15-2012, 05:45 PM
Rep: 119 Posts: 475
OK WestVanHan, sorry if I said something wrong but I do not understand why we can not use information that the engine manufacturer provides. Cautiously or wrongly, is often the best information we can provide. On the other hand, you're right, not only are the main engines that consume fuel, we must take into account all other consumers of fuel in the boat. So I think that neither yours nor my data can answer this question. Finding a yacht consumption, and therefore its autonomy, is quite complicated. But. if the manufacturer gives us a data, why not use it?
It's not that I try to help but not answering the question. It is, in my opinion, that if we do not use data as I propose is very difficult to estimate the consumption / autonomy of a ship, with rigor.
Old 09-15-2012, 06:37 PM
WestVanHan's Avatar
Like I said..it's good to try and help,but unless you know the drag/hp needed to move it-charts are not useful.
I have answered the question-again-my data is based on measuring and experience,not guessing off charts.
If you think you can solve it-tell me what lph is at 14 knots and what lph is at 16 knots.
Hint: 14 knots is off plane, 16 knots is on plane.
Old 09-15-2012, 11:42 PM
WestVanHan's Avatar
Jim; forgot to mention there's been a Sunseeker 94 docked here in Vancouver for 12-13 years.I know it had very very rarely been away from the dock up to 2009. I walked and biked past it almost every day.
And the last 4 years AFAIK it' hasn't been away much either,I'd guess for haulouts or runs. It was on the market continuously until a couple years ago-but I'd guess they still think it's worth the $4M they were asking for it in 2001.
Oh and the tankage on the 84 was 7500 or so..so at 10 knts you should go ~850 miles to empty-more than enough to circumnav. the Island and spend a year parked in the Broken Group if you wanted.
Old 09-16-2012, 07:22 AM
Rep: 836 Posts: 3,606
"not to thread jack, but how about two engines on one shaft, so.....
you aren't lugging a big diesel at lower speed, but still got full power with both engines running."
The past 40 years or so the US Navy has been installing two engines tied to a gear box and single shaft on landing craft.
My preference would be for a smallish diesel to operate efficiently at 80% power 90% rated RPM for long range cruising, and a stock motor for the times to make a big wake and de-fuel the boat rapidly.
3-71 and 6-71 or
80Hp Deere tractor with Intl DT 466 ,,more Modern , might use less fuel
Engine can be disconnected under way , but requires shut down to engage to reengage either engine.
No big deal.
Old 09-16-2012, 10:17 AM
3-71 and 6-71 or
No big deal.
Yeah, I saw two and four 6-71 tied into a one tranny in a Landing craft. The tranny was used and and need to be shift manually to engaged or this engaged them. But I thought it was a great idea. The problem has to do with a prop that works at 6-12-18 cyl. You would need a variable pitch prop to match. The whole setup is very complicated and obviously expensive that is why you don't see them.
Those sunseekers are not trawlers and not meant for range or efficient fuel consumption.
Fuel consumption poplariv Diesel Engines 11 01-17-2011 03:41 AM
Fuel Consumption JCD Powerboats 9 01-23-2008 02:08 PM
Fuel Consumption ashbana Boat Design 0 06-21-2007 05:52 AM
Fuel Consumption Poida Boat Design 27 05-10-2006 07:15 AM
Fuel consumption? duluthboats Boat Design 7 01-06-2006 06:07 AM
