Old 06-08-2009, 05:05 AM
rithul rithul is offline
Rep: 10 Posts: 4
FRP in boat building
can anyone tell me the emphasis on FRP boat building in the design of pleasure crafts.
rithul
Old 06-08-2009, 05:44 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
Can you narrow down your 'simplistic' question....
Old 06-08-2009, 05:46 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Commonality in the market?
Doesn't require the maintenance that wood does (and very very little maintenance during the first 5 years - good for repeat buyers)
Easier and cheaper to create complicated and curved shapes and provide a perfect shiny finish than aluminum
Or?
Old 06-08-2009, 05:51 AM
Rep: 10 Posts: 4
i need tu know its advantage in design of boats. . .
Old 06-08-2009, 06:38 AM
chris.dymond chris.dymond is offline
4.8 metre Sailing Dingy
Rep: 24 Posts: 70
you can form any shape you like
Old 06-08-2009, 06:57 AM
Rep: 700 Posts: 3,208
After the mold is created reliativly unskilled labor can perform most of the grunt work on building the hull.
The gel coat sprayer (if used) and supervisor will need some skills , but the rest of the crew can be taught to do good work in a 1/2 hour.
Molds can be purchased , custom made to your design.
Go to http://www.proboat.com/digital_issues.html and see what is offered.
FF
Old 06-08-2009, 07:33 AM
Previous Member
Rep: 0 Posts: 0
It is well suited to small production runs. The tooling required is not very expensive to get a high standard of finish.
Its mechanical, chemical and physical properties are well suited to the marine environment:
Good chemical resistance.
Resistance to weathering - both biological and chemical.
Good strength to weight ratio.
Good fracture toughness. (Particularly at high strain rates experienced with small planing craft.)
Single form hull construction with ability to easily selectively adjust thickness in higher loaded areas. (Welding of metals dramatically reduces their fatigue resistance. Butting different thickness metal plates creates stress raisers.)
Relatively easy to repair. (Most hardware stores stock fibre mat and polyester resin.)
Exposes hard wearing surface so will resist abrasion.
There are issues such as delamination and water absorption that damages the bonding. These can often be traced to poor construction practices.
If you make a table that sets out the mechanical properties, physical and chemical properties of common boat building materials such as wood, aluminum, steel, GFRP, carbon reinforced epoxy resin, etc along with price of tooling and raw materials you will get some idea of where it sits in the spectrum.
FRP shaft strut mikereed100 Fiberglass and Composite Boat Building 17 12-13-2009 11:03 AM
building an FRP barge in sections sailfaiz Materials 1 01-25-2008 08:16 PM
FRP vs CF Seafra Fiberglass and Composite Boat Building 18 09-04-2006 05:08 AM
FRP exhausts cyclops Boat Design 5 11-04-2005 06:30 PM
Exhaust of FRP Alik Boat Design 8 11-02-2005 09:26 PM
