#121
| Marc, It's 16.5 to 17" and I'm 5'10.5" tall. Hands and feet move the same distance as the line (rope) from the foot pedals is attached to the heel of the pedals and to the "D" ring that the hands pull on. So the feet apply power (pull) at the same point as the hands. The foot pedals move fwd under the power stroke pulling the lines around 2 pulleys just behind the rower and then forward pulling the D ring handles back. D rings are held by the hands and attached to the oar 17" out from the oars fulcrum point in the center of the boat. See Ron's website at front rower.com. One can row w feet only as well as arms only. I think the price is $1850 so it's not cheap but it's very well built. All the wood is varnished Cherry. |
#122
| Ron and I have similar mechanics in our bow facing rowers, I believe, except that he decided to pull from the middle and I oppted for pulling with linkage from a forward position. I could make arguments for either position. One advantage bow mounted oars may have is the gearing adjustment. From hull pivot to oar tip I have 86.5". I have multiple through holes in my foam filled alloy oar shafts which I have currently set at 21.25" out from the hull pivot for the leg drive line and 24.25" upper body drive. So I like a 15% differential in gearing between legs and arms, I think . I just got this out after years of nonuse so I may change my mind. Five knots was comfortable with this gearing. |
#123
| I've nearly finished my front rowing system, which is basically a modern version of the system used on duck punts back in the mid to late 1800's. Here are some photos of the unit minus the handles (I'm still waiting on some bar to turn these up). ![]() This is the position more or less at the catch. ![]() This is the position more or less at release. ![]() The system allows the oars to go over-centre so that they can be shipped properly. ![]() Here's a close up of the linkage, which uses some cheap stainless steel rod ends I bought from ebay for the link pivots. The main bearings are oilite bronze bushes running on stainless steel pins. ![]() The alloy plates that carry the linkage and vertical pivots rotate around the horizontal axis on these oilite bushes, held in an alloy block that's bolted to the end of the outrigger. The boat is the SOF one in the "Beautiful skeleton" thread. Jeremy |
#124
| Jeremy, is it fixed or sliding seat? I'm seeing only 2' stroke. At least the angle of the handles looked pretty reasonable at the extremes unlike some double jointed rigs. I see you've also set it as "high geared" (short stroke/long swept). Why not just shove some dowels into the pipes for handles, or even whittle down a tree branch? |
#125
| It's fixed seat (at least for the time being). The ratio of handle angle to oar angle is 4:5, so there is a 20% increase between handle and oar movement. I've arranged the pivot points and link length to get a system that accelerates the oar from the catch to the release, as my current thoughts are that this makes sense in terms of accelerating the boat (although I may well be wholly wrong on this). I've tried to keep the handle angles reasonable, because I'm not as young as I was and would rather pull hard and short, without flexing my wrists too much, than pull with a lower force over a wider angle. I would rather fit the proper handles before I get to row it, as it needs some counterbalancing, by adding weight inboard, to make rowing less hassle. With luck I may get to try it on the water the weekend after next. Jeremy |
#126
| Jeremy, Beautiful work, it will be good to hear how you like it. It looks light, would you like to share the all up weight with us? |
#127
| For what its worth I think the front faceing rowing is getting overly complicated here. I have and still do front face rowing. On larger boats I like to stand and push my body weight forward into the power stroke on canoe types lateral extensions for oar locks are in order here I sit and push my arms and body forward into the stroke or will do the fishermans single alternating stroke. It works but never close to as efficient as the standard rear faceing methods moveing seat or not. The most efficent system I have ever seen or used is the fixed seat moving oar rig. Here the butt and most of the body weight stay in one place and there is little if any hobby horseing with a full lenght full power leg and arm extension stroke. I believe this system was outlawed for racing rigs(probably too good) |
#128
| Thanks for the kind words. The boat weighs around 15kg (about 33 lbs) but I haven't weighed the front rowing kit yet. My guess is that it adds another 5 or 6kg (around 10 to 12 lbs). |
#129
| Jeremy, It looks like some of my ultralight aircraft projects of the past. |
#130
| Good spot! My background was light aircraft design (as a hobby, before I switched to back to playing with boats again). The frame is built pretty much like an ultralight, light alloy tubes fastened together with stainless steel blind rivets, with epoxy/glass over foam for the stem and transom. There are some other pictures on the "Beautiful skeleton" thread. |
| Could a paddlewheel be placed at the front? | djwkd | Boat Design | 63 | 06-23-2010 03:29 AM |
| Forward facing rowing system feedback? | kayaker50 | Boat Design | 22 | 01-04-2010 10:45 PM |
| outboard in front? | wjquigs | Propulsion | 9 | 09-06-2009 11:57 AM |
| Motorsailer with pilothouse in front | YuriB | Motorsailers | 18 | 06-24-2008 06:04 AM |
| Front End Engineering Department | pashbe1 | Boat Design | 1 | 04-21-2008 08:54 AM |
