Old 11-05-2006, 09:25 AM
Et' Et' is offline
Rep: 10 Posts: 2
frictional resistance Froude's formula
Hi!
could anyone define γ in the Froude's formula:
Rfriction = (λγ/1000) . WSA . V^1.825 where: λ=0.1392+[0.258/(Lwl+2.68)]
kind regards. thank you
Old 11-05-2006, 10:39 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Usually when I see a gamma (is that the letter you're referring to?) in a formula, I think 1/sqrt(1-v^2/c^2). Since sailboats do not travel at a significant fraction of the speed of light, I presume that's not the one you're after?
Old 11-05-2006, 11:20 AM
french44 french44 is offline
Rep: 63 Posts: 23
hi,
I read your formulation and i think you lose a piece of . I use to froude methode and the right name is froude le besnerais and the formulation is:
Rf/D=(1+0.0043*(15-t))*(S*Lwl/VO)*(0.1392+(0.258/(2.68+Lwl))*(Lwl^-0.0875)*(V/(Lwl^0.5))^1.825
D metric ton
t water temperature in degree
V m/s
Lwl m
S mē
V0 cubic meter
Old 11-05-2006, 02:17 PM
naval ark naval ark is offline
Member
Rep: 19 Posts: 27
Originally Posted by Et' View Post
Hi!
Gamma is the specific weight of the water you're testing in, close enough to 1000 kg/m^3 if fresh water, so it's just there to account for other densities.
As touched on, the formula is only technically correct for water of 15 degrees C, and the (1+0.0043*(15-t)) term handles the temperature differences. If you wish to use a different temp, just put this term in the numerator.
And don't forget that the Rf is given in kgf - not N!
Good luck...
Old 11-05-2006, 02:32 PM
marshmat's Avatar
"And don't forget that the Rf is given in kgf - not N!"..... Empirical formulae drive us physics types nuts! It ain't hard to make an equation dimensionally consistent....
1960s Formula TAB Powerboats 1 02-18-2006 09:43 PM
1960s Formula TAB Boat Design 0 01-10-2006 11:09 AM
rudder's joessel formula fede Boat Design 4 12-19-2005 12:19 AM
Simpson's formula Coen Boat Design 6 03-03-2005 02:40 PM
floatation formula Boat Design 10 07-14-2004 05:27 PM
