Old 07-14-2008, 11:13 AM
ConcreteCanoe10 ConcreteCanoe10 is offline
Rep: 10 Posts: 4
Freeship help
Hi,
I am a third year civil engineer and co-caption of this years UMaine concrete canoe team. I am looking for some help with freeship. I have been using it for almost a year now and I have successfully drawn many canoes. However, I still do not understand a lot of the information FreeShip gives me about my boat, nor do I understand how to get the information I want.
I would really like to be able to put in a wall thickness and a density. I am also interested in drag, top speed, and anything else that might be useful.
Thanks!
Old 07-14-2008, 04:16 PM
Previous Member
Rep: 0 Posts: 0
Thickness - enter the data in the "Layer" information window.
Drag - Freeship does not provide meaningful information on drag for a narrow craft like this. Better to use Michlet.
Top Speed - how many paddlers and what power can they produce? You can assume a paddling efficiency of 60% if average. Maybe 70% if they have good technique.
Rick W.
Old 07-15-2008, 06:42 AM
Rep: 10 Posts: 4
thanks!
Old 07-15-2008, 04:10 PM
verbertus verbertus is offline
Rep: 36 Posts: 26
Hi Rick,
Are you saying that the Kaper resistance calc ( John Winters), which is one of the drag calculations in Freeship+, is giving no meaningful information?
Old 07-15-2008, 04:44 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by verbertus View Post
Hi Rick,
The version of Freeship that I have does not give any results for certain block coefficients that can be found with very efficient slender hulls. Where I have got results they do not compare well with Michlet and I have found Michlet gives very reliable results for efficient hulls.
I now have Delftship Pro and it has two empirical methods. They do work for high block coefficients. The results vary by 30% or more between the two methods in some situations. I am designing to within 3% using Michlet. The great benefit with Michlet is the in-built hull optimising routine Godzilla.
The wave drag in Michlet is determined using an analytical method whereas the others use empirical method.
Rick W.
Using FreeShip pairomedicsfish Software 12 10-05-2011 01:25 PM
FreeShip lewisboats Software 6 08-03-2009 11:52 AM
freeship question pavel915 Software 7 08-01-2007 01:58 AM
From Rhino to Freeship mkovac67 Software 7 04-06-2007 04:37 AM
FreeSHIP 2.1 lewisboats Software 5 11-06-2005 05:35 AM
