Old 05-07-2005, 01:01 AM
Alik's Avatar
Alik Alik is offline
Rep: 543 Posts: 946
Freeboard requirements
I know ISO requirements for small craft freeboard. Are there any smal lcraft freeboard regulations? And how they are related to Load Lines regulations for big ships. Give links, if any. Thanks...
Old 05-07-2005, 09:38 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1449 Posts: 3,976
That would be up to your national regulatory agencies. In Canada, there are a number of equations used to calculate hull load based on hull shape and volume; we base our load for small craft on one-fifth of the static float plane volume. The minimum freeboard is not expressly stated; ISO requirements are best to go with if you think they are applicable.
The behaviour of a small craft is quite different from that of a large ship. As far as I know, the load lines on commercial vessels bear no relationship to the freeboard on small craft- indeed, if you tried to use the same equations, your small boat would be swamped within minutes of leaving the harbour.
- Matt Marsh - http://www.marsh-design.com/
Computer Requirements for Boat Design Konaphil General Computing 19 09-25-2008 08:33 AM
Formula to calc HP requirements of pontoon rduval Propulsion 3 07-01-2006 03:21 PM
freeboard capt'n ron Boat Design 3 08-12-2005 08:45 AM
freeboard, how much is enough? dionysis Sailboats 23 11-07-2004 01:05 AM
Design help needed! Odd racing requirements! Boat Design 1 08-15-2002 01:05 PM
