Free!Ship Design Help 5.5 Planning Hull
Discussion in 'Boat Design' started by RoBoT6779, Jul 21, 2013.
  1. DCockey
    Likes: 634, Points: 113, Legacy Rep: 1485
    DCockey Senior Member
    Thanks. That's a fundamental difference from Rhino which can create a developable surface based on two input curves such as the keel and chine or chine and sheer. Of course the input curves have to suitable as opposite edges of developable surfaces.
  2. quequen
    Likes: 15, Points: 28, Legacy Rep: 199
    quequen Senior Member
    Just in case, you can download the Freeship 3.41 small version (free of malware) directly from this post:
    http://www.boatdesign.net/forums/de...-michlet-transom-sterns-47214.html#post641708
    Be aware: do not visit any of the web pages that come into the .txt files
    David: Freeship Developing routine is pretty interesting, particularly when developing non totally developable surfaces: it colour the bad regions, makes up to 25 iterations to find the better solution, and after development shows the reached accuracy for each plate, so you can take your own decisions about modifying and refining you surfaces.
  3. RoBoT6779
    RoBoT6779 Junior Member
    Now I have my computer up and running again, I've finally been able to look at your answers. 5.4v2 is exactly the way I want the hull to be designed. My knowledge tells me that these ruling lines should all come from a single apex point (how ever far off into the distance). Is there a command or function to align the control-net this way, or is just hit and miss place them where you think??? FYI I will be using the same method for the sides of the boat. QueQuen your download worked perfectly. Thanks
  4. jarmo.hakkinen
    Likes: 3, Points: 8, Legacy Rep: 25
    jarmo.hakkinen Junior Member
    Actually, the ruling lines don't have to come from a single apex point, but can be a combination of parallel (Cylindrical) lines and lines from apex (conical). The trick is, that when changing from one to another, the edges of them must be joined, i.e. Apex of the cone must be on the side line of the cylinder, and the new apex of different radius and height, must join the edge of the previous. Hopefully the picture clarifies it a bit. And there's this: http://www.boatdesign.net/forums/boat-design/request-your-input-my-design-47644-7.html#post641486
