| Thanks for saving the pics for us! What a collection of neat ideas! Not strictly a lateen - more of a leg o’ mutton sail, considering the sprit and near vertical mast.I would worry about the wear on the mainsail through the mid-boom support ring, if it is a ring, and if it is a ring then how can the sail pass through it for reefing/sailing? Must have a sail gap with rollers. Pity the original site has gone.
About the 'ring'... it looks to me like somthing like this... (example)Don't know if I used the correct names when I said.. ‘‘The lateen is hanging in the A-frame in with what seems to be a reefing claw.’’ About the wear; an extra layer of cloth on both sides of the sail where the rollers go..? and bigger diameter and wider rollers..? (see twin rollers for a start) I think this is a leg of mutton rig... (pic source)Calidris' main looks more like a lateen to me.. with the addition of a roller reefing system and a swiveling boom at the bottom to set it better to the wind and makes it easier to tack then a traditional lateen. Yes, a lot of neat ideas in it Cheers, Angel Last edited by Angélique : 03-12-2011 at 10:16 AM. Reason: added: ‘‘and makes it easier to tack then a traditional lateen’’ |
| Yes, I think you are right about the ring, whatever it is called. It must get a lot of strain put on it in a breeze. The sail in your last image is a type of leg of mutton as you say, but it is more commonly three-sided without the club at the end of the sprit. The reefing system is not relevant to the type of sail IMHO. I've never seen or heard of a lateen with a sprit whereas LOM's usually have one. The loose-footed three sided sails I have seen are more or less horizontal along the foot - presumably to keep the clew low - not a problem with a sprit. I found this definition of a lateen "A triangular sail, extended by a long yard, which is slung at about one fourth of its length from the lower end, to a low mast, this end being brought down at the tack, while the other end is elevated at an angle or about forty-five degrees ... Some lateen sails have also a boom on the lower side" That last bit is getting awful close to a crab claw. Perhaps we should split the difference and call it a calidris sail ... it's unique enough to have its own name.
| Right, a Calidris sail it is Cheers, Angel |
| The Mastless Crab Claw ? discussion is related
| Try this thread WishBone Sailing Rig Lots of similar ideas. |
| Jean Merrien a French sailor and designer in the 1960 built several cruisers with A frames masts and two keel. He was quite successful for a while with the A frames. I find it odd and not very appealing. but it's me Lister
__________________ "I always like walking in the rain," he said, "so no one can see me crying." Charlie Chaplin |
I added a link to your posting here to this much bigger discussion of A-frame related discussions: WishBone Sailing Rig Edited: Opps, 'upchurchmr' bet me to it with the cross reference. I hadn't got to the second page of this discussion before I made my posting ![]() |
#25
Cheers, Angel |
#26
| Angel, Calidris was a very limited part of the link posted by Brian and myself. And it applies to this thread, so why should we wait? And for What? Did you look at the whole linK? there are multiple different boats in the link. the only thing I didn't like is the people who say an A frame is terrible, and those who say it isn't with no facts. Fortunately there are some who have enough detail to lead one to make their own decision. Like the people interested in this thread. Do you not like Calidris? |
#27
) but was talking about the links posted there . . . . (note the word ‘‘there’’ in the post you replied to)Quote:
![]() Cheers, Angel |
| A Frame Mast - Aft | gonewalkabout | Boat Design | 16 | 08-14-2010 05:06 PM |
| Frame | bachainsaw32 | Powerboats | 2 | 07-20-2007 10:25 PM |
| multihull frame | nukem419 | Boatbuilding | 1 | 06-08-2006 02:06 AM |
| Attaching Flooring frame to Rib Frame. | jeff goldberg | Boat Design | 0 | 05-24-2006 01:34 PM |
| Keel And Frame ? | MACINAW | Metal Boat Building | 5 | 05-05-2005 12:20 AM |
