Old 03-11-2005, 03:40 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Four hulls better than two?
Gentleman, can you explain design concept of this contraption and what do you think
Wynand
A scatterling of Africa
Old 03-11-2005, 03:53 PM
Rep: 1729 Posts: 2,460
The amas retract into the hull sides, looks like a pet project of a student that got built, supposed to be trailerable I suppose, I wonder how she sails?
Mike Johns.
Old 03-11-2005, 05:01 PM
icetreader icetreader is offline
Rep: 12 Posts: 189
Parking space
Takes less parking space at the marina
fishing kayaks
Old 03-11-2005, 10:47 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
Funky!
It looks like they added the second forsail later - could that be to compensate for the higher wetted surface of 4 skinny hulls??
I like the Marina advantage.
May the wind blow briskly in your sails!
Old 03-12-2005, 12:53 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
The second foresail at the end of the bowsprit is called a "screecher" and it's just about universal on modern multihulls. It's used when reaching, for going to windward in very light winds, and as a heavy-air substitute for a spinnaker. Typically dropped when not in use, however.
There have been other 4-hulled boats built. But they have most of the worst characteristics of catamarans and trimarans. Excessive wetted area, irreducible beam, expensive construction. The problem is how to fold a catamaran on the water - there just hasn't been a good solution perfected yet. Folding trimarans, particularly the Farrier designs, have proven to be far more effective. The only advantage to 4 hulls is theoretically you can divide the displacement into even narrower demihulls and achieve some reduction in wave drag. But that doesn't seem to be the way this design has gone.
Tom Speer
Old 03-12-2005, 02:46 AM
JimCooper JimCooper is offline
Rep: 10 Posts: 81
room to squeeze in out of the weather?
no room in those main hulls cause of the mould to take the outers.
Some designers just don't get the idea that you can marry comfort and capability.
can you imagine her in a big quartering sea ?
Leave it to the gizmo gadget brigade.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 06:54 AM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
ROCAT closed mould one-piece hulls cristofa Fiberglass and Composite Boat Building 10 07-15-2005 04:13 PM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 01:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
