Old 06-03-2008, 01:50 PM
Baywolf's Avatar
Baywolf Baywolf is offline
Engineer, who me? ya sure
Rep: 21 Posts: 33
A form of supercavitation...., possibly?
Ok, bare with me, i am no seasoned engineer. I was pondering a wicked little idea, being that I mainly toy with bay boats I need a fast slipery hull in shallow often 10" water, so I was curious would you say; If you created a dimpled surface of a hull (similar to a golf ball) and provide a constant turbulent flow of water between the bay and the hull, meanwhile having a second tunnel with a luminal flow of water or smooth to the intake for the jet you create a form of supercavitation over the surface of water or random vortexes and reduce the drag of the hull. Would this make a hull faster of simply at the most extreme amount of drag consievable?
!!!!!DRIVEN!!!!!
Old 06-04-2008, 08:17 AM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
A golfball like surface would increase your drag in the water. A 600 grit sanding would free up the bottom a bit. For what you ware wanting i would look into running a center tunnel with steps outside of the tunnel.
Old 06-04-2008, 09:23 AM
Baywolf's Avatar
Rep: 21 Posts: 33
That's essentially what I've got right now But i've begun to ponder instead of toying with the strakes and chines, what if the actual surface could be made to react different with hull. Another thing, if you punch hundreds of tiny holes in the dimples and eject air through them at different pressures would they amplify the ventalated hull idea, and is turbulance beneath the boat so bad, I think, the more turbulant the water at the hull, (not swales) the less drag the hull deals with, but I am by all means a nooby, so set me as straight as possible, please.
!!!!!DRIVEN!!!!!
Old 06-04-2008, 09:27 AM
Baywolf's Avatar
Rep: 21 Posts: 33
I know no equations exists for determining turbulance, only a bit of random theory equations, but I also know turbulance has been deliberately used to control exhaust and drag off of some planes, I just don't know how turbulance in water would affect the drag of the hull.
!!!!!DRIVEN!!!!!
Old 06-05-2008, 02:39 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
A form of supercavitation....possibly
Lots of air bubbles around the hull removes the support and can make even very large boat sink completely.
tomkane
Old 06-05-2008, 02:48 AM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 451 Posts: 506
I think the Russians had a torpedo for testing that were pretty blunt at the front... Don't know too much though. (Was that what they were testing with Kursk? tragic...).
http://de.wikipedia.org/wiki/Schkwal
But the view from a torpedo is pretty restricted...... : ;-)
KnutS
"it's dark and we're wearing sunglasses"
Last edited by Knut Sand : 06-05-2008 at 02:55 AM. Reason: But the view from .....
Old 06-05-2008, 06:04 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Do a search on these topics throughout the forum - there have been a lot of discussions about this subject - and a lot of similar ideas, including some crazy claims by a few chaps.
Dimples, bubbles, strakes, you name it - its all been covered pretty thoroughly
Supercavitation FranklinRatliff Boat Design 3 02-25-2006 03:46 PM
Has anyone ordered form SailboatsToGo? Anau Boat Design 4 11-01-2005 09:07 PM
New (possibly) idea for monohull stability in rough seas sryth Sailboats 45 08-24-2005 05:41 PM
Any and possibly all marine books dansea Education 2 03-13-2005 08:16 PM
Hull Form Hamidi Boat Design 0 08-11-2004 09:26 PM
