| Forefoot in or out of the water? I'm designing a paddle powered trimaran for nearshore fishing. The boat is inspired by the local 'banca' boats of the Philippines. It's almost 16 feet long and the main hull is about 2.5 feet wide. I've shown this boat with its forefoot out of the water, but others have questioned this feature. Should I keep the forefoot out of the water on a slow paddle powered boat like this, or should I re-draw it to make the forefoot fully sibmerged? And why?
__________________ Kenneth Grome |
| Straight rocker is more easily driven at displacement speed. If there is potential for surfing then having some lift in the bow will help. Having the outriggers in the water is energy wasting. If it is intended for operation in a bit of chop then you can place them higher than the waterline of the main hull. No point in having them bearing load until they need to in a roll. Aim is to have them do nothing most of the time. They are just there to prevent unintended swimming. Rick W. |
| Hi Rick, thanks for commenting ... Quote:
Lift - The flat section at the bow with the upward slope will provide lift if the hull is surfing down a wave. This is desirable compared with burying. My long slender hulls with little planning surface don't notice waves they just go straight through them. Not a good prospect on larger waves. What evidence have you got that slapping of outriggers is an issue for chasing fish. In any event it is hardly a good reason as they will still slap unless you lean one way and load up one of them and completely unload the other. You then have something more like an outrigger when at rest. When under way you aim to ballance the outriggers clear of the water. The little hulls will contribute significantly to drag if they carry any sustained load. I even use torsion bars on mine now so they roll over waves rather than carve through them. In some chop going to windward they get a real workout. Rick W. |
| If you're going to fish from it one of the things I would suggest is make sure the ammas won't submerge if you both stand on them, the most probable place to get the fish out (unless you cut the line each time or catch only small ones ). You would probably have a trampoline between the beams to walk on. Very nice to have.I agree with what Rick said. I think the bow on the waterline is ok, but if you have surf or breaking waves you may want the bow's deck heigh higher so a wave won't go over so easily. May wash your only fish off ![]() You mention paddle ? Is it a 2hp Mercury ? I would strongly recommend one... in case the wind unexpectedly pics up and you're runnling low on vitamins and callories for the day. I'm not critisizing... but I would make the boat as big as I think I can handle. It is always big on land but too small out there. Someone I know (he's a tough guy) bought himself a big paddle ski to fish from. It looked so big when he got it, but all that changed rapidly when he got it on the water. He didn't catch a single fish from it. Ended up surfing the waves with it... a lilo would have been cheaper Just my opinion.One other question... why not consider having a little sail on it ? You don't have to participate in competitions for speed, but you can however sail up and down and trawl all day long if you want... save the legs some ![]()
| By the way, in addition to 'torsion bar akas' I have also considered using self-steering amas ... My concept is to locate a vertical aka attachment tube at about 1/3 of the ama's length from the front. The aka's vertical pipe section would fit into this tube and allow the ama to swivel on the vertical axis to adjust to the varying angles at which they hit the waves and currents. Any thoughts on the viability of this concept? Edit: At one point I considered using this swiveling connection and locating short amas aft so they could function both as amas and as rudders in a similar engine powered boat.
| How do they slap? You assume the boat will be sitting flat. If there is any waves the boat will roll about. With waves a couple of inches high the amas will start to flop. Normal drift is side on. Possibly different if bow on but in this case even if the amas are above the water they will both always be in water contact in anything other than dead calm. A single torsion arm is fine. I use 25mm square aluminium tube that is 1.2mm thick. My current outriggers displace 15l so the force is limited. You would need something heavier. Drag is low so the risk of bending the tube is slight. My tube is triangulated with support braces as well but this is to do with folding system not really strength. But it does stiffen them up in vertical and horizontal planes; not in rotation though. Rick W |
http://www.graingerdesigns.com.au/st...detail-145.php Aim to keep both amas out of the water if possible. My OC1 has adjustable ama height so I can set the degree of twitchiness. With ballanced outriggers I can set them a little higher when there is chop to take advantage of just clipping the wave crests. On the same setting they would allow flop in calm water. I also set my amas to just skim the diagonal wave off the bow so they get a free ride using energy I have already put into the water. Hulls are about is inefficient as you can get as a foil so they do not make good rudders. The aft paddler will be most effective at turning the boat unless you fit a rudder. Rick W. |
If the main hull is stable enough, a better solution might be to have amas that can be lifted while in transit then lowered while drifting at the fishing grounds. I don't want this boat to get too complicated though, so if I do this the mechanism would have to be cheap, simple and reliable. Maybe it would be better to just remove the amas from one slot and slide them into another rather than trying to design some kind of complicated mechanism to allow them to rotate ... Quote:
Is there a particularly good ama shape you might suggest for use as torsion bar amas?
http://www.youtube.com/watch?v=ckWqIgmVM4Y The PVC pipe is not mine but I used the same for a fast build and it was copied here. They do not displace enough. In this case they are also always loaded because the boat is stern heavy. The orange ones are end-on-end cones mounted offset so they present a straight rocker. These are good in rigid set up. They work very nicely in chop. The black ones are intended to plane. They have raked entry and flat run through middle and aft. The aft is tapered so it leaves clean at low speed. These have more distributed buoyancy than the conical ones and work well on the torsion arms. The lift quickly on a wave pitching up then down as they roll over a wave. Gives slightly less drag than if they were rigidly supported. I have had concern about fatigue when you see them working hard into chop but I think it would take a lot of miles. Rick |
| deeper forefoot | mcollins07 | Boat Design | 28 | 03-28-2009 05:13 AM |
| Osmosis - Fresh Water vs Salt Water | andy_uk | Fiberglass and Composite Boat Building | 0 | 05-21-2008 02:40 AM |
| normal at forefoot | rhiemstra | Software | 7 | 01-31-2007 12:15 AM |
| No water in oil pan, But water in oil filter? | midtower | Gas Engines | 14 | 03-19-2005 05:43 PM |
| Fuel, water, black water tank construction | kudu | Boat Design | 12 | 07-25-2003 06:54 PM |
