Old 02-27-2011, 11:58 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Foredeck Hatch
I'm looking for a supplier for a foredeck hatch that is to be fitted to an aluminium powerboat.
The hatch needs to be essentially flush fitting, so that it can be decked over with teak or similar to match the surrounding foredeck.
It also needs to be rellatively light weight, which seems to the main problem with all the off-the-shelf units that I've looked at so far from the likes of Bomar, Olcese Ricci etc. which all weigh 20kg or more.
At the end of the day, we can always fabricate one, but my experience with hatches is that they always work better if they are production units...
Any suggestions much appreciated....
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 02-28-2011, 12:11 AM
mark775
I didn't know of this company, thanks. http://www.olcesericci.com/yacht-boats/en_LY.htm This looks of good quality.
Old 02-28-2011, 01:51 AM
Rep: 670 Posts: 2,457
Rondal supplies hatches and doors to the yacht industry. Carbon or Aluminium.
Be warned....have a seat and hold on firmly when you receive the quote...you could be overwhelmed by a case of the Vapours when viewing those long unbroken stings of Euro numbers.
http://www.rondal.com/index2.php?pag...e_name=Hatches
Old 02-28-2011, 02:17 AM
Yes - as I noted, I have the info on both Rondal and Olcese Ricci. Both make very high quality stuff - but are intended for larger craft - not an 8m tender, which is weight critical....
Will
www.imaginocean.net
Old 02-28-2011, 02:52 AM
Hmm...I have two custom profile, deck cambered, aluminum Rondal foredeck hatches and without their teak skin they are very light....and cost as much as a small car !!!!!!
I suppose to save money, you could design the foredeck with a recessed, flat non deck cambered base with drain waterways to accept a standard anodized Lewmar low profile. On small race boats Ive modified the standard Lewmar type by substituting the window with a sheet of skinned Nomex or skined HD foam . Skinned Ply set in the frame would work .
It would make more sense to use an off the shelf , none deck cambered hatch. Custom Hatches are high maintenance....paint and corrosion ... and Rondal service components like gaskets are expensive and time consuming to order.
Old 02-28-2011, 04:38 AM
Yes - I have thought about doing that, but I'd far prefer to use a simple off-the-shelf unit in its intended fashion.
Cost is not the (major) issue... the expense of custom fabricating (usually) far outweighs the added expense of buying quality.
Oh.. and no deck camber BTW
Will
www.imaginocean.net
Old 02-28-2011, 04:40 AM
Did you review FREEMAN hatches ?
http://www.freemanmarine.com/Hatches3400Series.htm
Old 02-28-2011, 04:44 AM
The Vetus Planus hatch is also very low profile and looks easy to modify , remove, glass panel
Old 03-01-2011, 05:24 AM
I've looked at the Freeman stuff before... perhaps worth a re-visit though... thanks
I have a planus hatch in my current boat and I agree, repplacing the "plastic" with something that could be decked over could be a work-around... though I'd be hesitant about having people walk over it on a regular basis.
In the end, I may have to accept making up a small recess and using a "normal" hatch...
Will
www.imaginocean.net
Old 03-01-2011, 06:59 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Lewmar has them in catalogue, as well as Bomar:
http://www.lewmar.com/
http://www.pompanette.com/bomar
Old 03-01-2011, 07:45 PM
Thanks Slavi, but neither offer a hatch suitable to be decked over, unless I've missed it.
The Lewmar flush hatch is an option, however... if I foregoe the decked-over approach
Will
www.imaginocean.net
Old 12-13-2011, 09:16 AM
longboat1 longboat1 is offline
Pacific Coast Marine...High Quality, low cost
Tenders stored on foredeck sabahcat Boat Design 66 11-29-2010 01:33 AM
How To Install A Hatch Ring On A Foredeck bobk Metal Boat Building 1 07-30-2010 08:34 AM
foredeck layout pengreg Sailboats 3 05-05-2005 05:49 AM
Cockpit hatch drs3317 Boat Design 0 03-31-2005 07:51 PM
Foredeck Mooring Hardware Lew Morris Sailboats 10 06-14-2003 05:46 PM
