| Force Hello Everyone! I am starting a project, a 30 Horsepower 13 foot mini cigarette. I will be needing much help, as well as many tips and tricks, as this is my first boat. Thanks in advance everyone for your revealing input! |
| Do I need to glass both sides of 3/4 inch ply, or can i simply glass the scarfs? Will this be strong enough. Also will I need to pu in ribs, or can i bend the ply w/ out ribs? I am building up from a caribe bottom. |
| You can't bend 3/4" plywood you need 2 layers or 3/8". |
| how bout 1/2 inch |
| 1/2" ply will be very hard to bend into the tight curves of a 13-footer. Rasor's suggestion of two layers 3/8", staggering the seams, is the way to go if you need a 3/4" thick hull. Still, that's awfully beefy for a 13 footer.
| You will have to post some pictures so we can see what you're starting with. Are you building up the sides of the pre-existing boat bottom or are you using the bottom of the caribe as a former to make a new bottom? For speed you want lightness (i'm assuming you want to go very fast?..) so do not use 3/4 ply anywhere apart from knees and other small reinforcements.
__________________ T.T.T. a.k.a. T³ |
| Thermostat on Force 9.9 | Joe Morrison | Outboards | 1 | 01-04-2009 03:57 AM |
| Rudder force | eight | Boat Design | 0 | 07-19-2007 02:18 PM |
| force from a sail | man308 | Sailboats | 5 | 02-20-2004 11:44 PM |
| Hydrodynamic Force | Guest | Boat Design | 2 | 02-18-2004 10:54 AM |
| Force Created By Propeller | DUCKHTNR | Boat Design | 4 | 04-11-2002 12:30 PM |
