Old 11-05-2008, 10:24 AM
haybayian haybayian is offline
Rep: 10 Posts: 24
foil profiles
I am trying to design a hydrofoil and I am not much of a designer. I wonder if one of you could point me to existing dimensional drawings of foils which I could use as reference. My application is a light two seater watercraft with aircraft propeller and two steps ladder foils in canard configuration. I hope to reach a speed of 50 kts with a 1500 cc Mazda engine.
Thanks for your guidance.
Haybayian
Old 11-05-2008, 11:57 AM
JesperW's Avatar
JesperW JesperW is offline
http://journeyman.se
Rep: 54 Posts: 45
Wow, that's a big question. Problem with using a readymade profile is you need to know what speed/lift etc it is designed for. Big risk of going astray here, if you don't want to learn the basics of airfoil properties...
Software such as http://aerofoilengineering.com/ or http://www.winfoil.com allow you to play around with profiles and results, they have trials and are cheap. Try it, you might become a bit more of a designer!
/j
Old 11-05-2008, 05:20 PM
clmanges clmanges is offline
Rep: 32 Posts: 258
This might be a good place to start . . .
www.foils.org
Old 11-08-2008, 01:15 PM
Rep: 10 Posts: 24
Thanks to you both for the tips. Yes I am aware of the complexity of my question. I was only hoping to find drawings of existing hydrofoil profiles that I could copy or adapt to my needs without getting too deep into hydrodynamics.
Haybayian
Old 11-08-2008, 05:44 PM
aka Terry Haines
Rep: 1811 Posts: 3,007
I got a lot of help through my own thread at
Hydrofoil Profile Question
This is a resourceful site: http://www.gliders.dk/airfoils.htm
This page has a NACA four digit profile generator and links to a NACA five digit generator: http://www.ppart.de//programming/jav...les/NACA4.html
Dances with Turkeys
T-foil national Sailboats 14 06-25-2007 11:31 AM
Foil planforms Rolf Nilsen Multihulls 6 07-22-2006 08:46 PM
HSVA Profiles Ajanko Boat Design 4 03-02-2006 01:39 AM
hull profiles??? =D= Software 3 03-13-2005 08:07 PM
Rudder and daggerboard profiles. Sailboats 37 08-31-2004 12:58 AM
