Old 06-23-2006, 12:57 PM
basenjib123 basenjib123 is offline
Floor/motor mount for 14' open bow aluminum boat
Hello all, I just found this forum and I am excited and eager to learn from what looks to be a great source of information! I have a 14' open bow aluminum Starcraft boat. This boat has flooring with the exception of the very front section at the bow area. I would like to add a floor section there using either the same material (material there now seems to be some sort of composite material, I do not know what or where to get it..it appears factory installed). Also, I have a foot operated electric motor and battery that I would like to install at the bow. I need a mounting surface for the electric motor and a place to secure a battery. I guess you could say I am looking to turn my open V-Bow into a 'Bass Fishing boat'. I sure would appreciate any ideas, opinions, sources, etc. Thanks in advance, Joe
Old 06-24-2006, 02:19 AM
im412 im412 is offline
Rep: 5 Posts: 61
first example i came across, if you search existing topics there will be photo's explaining what was done
in australia aluminium boats are called tinni
http://www.ausbream.com/forum/topic.asp?TOPIC_ID=2025
http://www.breammaster.com/forum/for...php?forumid=25
lots of info in the various forums on how to fit out and replace a floor...
in your case use this info to complete your flooring
cheers jack
Old 09-28-2006, 01:57 AM
ducknuts's Avatar
ducknuts ducknuts is offline
Rep: 12 Posts: 16
If you do a search for modifying a jon boat you get all kinds of info on doing this. My boat already had this done when I got it, they built a platform on top of the front seat that extended back about eight inches off the back of the seat and four inches in front, then screwed it to the top edges of the seat. Next they built a triangular piece that fit between the front of the platform and the inside of the bow, attached it with hinges to the platform and it rests on the inside of the vee at the front, basically wedging it in place with a piece of rope for a handle.
I can only speak from my own experiences and knowledge, both good and bad.
bow engined motor boat cajunseadog Boat Design 1 06-13-2006 08:13 AM
pontoon motor mount kcard2112 Boat Design 1 05-11-2005 10:43 PM
Adding full tramsom motor mount / dive platform Kaptin-Jer Sailboats 2 03-04-2004 07:59 PM
Open Floor Plans Uncle JT Sailboats 2 09-02-2003 11:39 PM
redoing floor in bow rider ventnorbuilder Boatbuilding 4 07-23-2002 09:38 AM
