Old 07-23-2009, 08:28 PM
barrienxtgen#9's Avatar
barrienxtgen#9 barrienxtgen#9 is offline
Floor
Hi this is my first on here, I have read some of the post and you all seem to know your stuff. I have had a boat given to me and it needs a new floor put in it. I just want to know the best way to go about this. I really don't want to remove the current floor just because its glassed in, how ever would cutting around the edge of the old plywood and removing most of the old floor do? or could I just lay over what there?
Thanks Chris
Plus does anyone know of a web site I could use to search the model number on my boat??
Old 07-23-2009, 09:20 PM
Ike's Avatar
Ike Ike is offline
Rep: 490 Posts: 926
Lay over what is there and you will just get a rotten deck. Cut the old deck out and install new. Seal the plywood with epoxy resin and it will last longer than the original.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 07-23-2009, 11:49 PM
alan white's Avatar
Rep: 675 Posts: 2,787
Be prepared to find even more rot once the old deck is off. This forum should really be called the sole and stringer forum, since nine out of ten posts deal with rotten plywood framing and panels.
There are a lot of threads, in other words, chock full of good advice. Use the search function. Good luck.
What is this under the floor? wheresbob Powerboats 9 08-06-2006 09:26 PM
Redoing my floor Steve71 Fiberglass and Composite Boat Building 2 04-30-2006 09:44 PM
Replaced Floor leroy Fiberglass and Composite Boat Building 5 08-05-2004 08:41 AM
floor gone- now what? Guest Boatbuilding 0 06-23-2003 04:37 PM
What to use for floor? Materials 4 08-06-2002 11:23 AM
