Old 07-14-2008, 11:56 AM
Baywolf's Avatar
Baywolf Baywolf is offline
Engineer, who me? ya sure
Rep: 21 Posts: 33
Flats Skiff Catamaran Design Input wanted?
I'm a small builder, I like bay boats and skiffs, I found this little number in a pile of old papers and I think I'll finally get to refining it and building a plug. It is an extremely light, really simple effiecient design. It will likely measure 22' long, 8'6" beam, and use a 140-175 hp. The mid section on the tunnel are slight, about only a 1" height by whatever width at that point, and the gunwales aren't shown, but I wanted to see what reaction it would get and maybe some ideas, so the design doesn't look so 80's, lol....
My oldie is online at Baywolf Boats website.
!!!!!DRIVEN!!!!!
Old 07-14-2008, 04:22 PM
Baywolf's Avatar
Rep: 21 Posts: 33
Baywolf Boat Concept SWA
Hers's another one, but I think it's asking too much, It might prove to be too far ahead for it's time...lol...
Actually this one is being molded already, the plug, ah, the plug, "the heart and soul of all your efforts, into something that you cannot fish off of", so sad, but necessary.
!!!!!DRIVEN!!!!!
Old 07-15-2008, 11:33 AM
Baywolf's Avatar
Rep: 21 Posts: 33
How about a SS hybrid?
Here is one that toys with SS double quadrehedral, channels a high percentage of the water to the prop at low speeds to get a higher level of reponse in shallow water hole shot condition.
!!!!!DRIVEN!!!!!
Old 07-15-2008, 01:44 PM
xboats's Avatar
xboats xboats is offline
experimenters
Rep: 10 Posts: 9
Stunning! Love the outer shape of your 3rd drawing (posted today 11:33), with your 2nd drawings tunnel -- least drag.
Question: Wouldn't widening the tunnel in the mid section, cause cavitation ?
Old 07-16-2008, 12:50 PM
Baywolf's Avatar
Rep: 21 Posts: 33
Technically.
Xboat, your right, but once youre on plane the hull rises on a set of pads and the tunnel becomes obsolete, the tunnell will only be needed during the first 10 meters or so of launching in a hole shot, supposed to be a shot pressurized water trying to exit at the prop in a hard sand bottom situation.
!!!!!DRIVEN!!!!!
Old 07-16-2008, 05:08 PM
Baywolf's Avatar
Rep: 21 Posts: 33
Here's a bay boat with some'tin!
I was giving an old bay boat desing, and injecting a tiny bit of sea-doo to see what might happen.
!!!!!DRIVEN!!!!!
Old 07-17-2008, 09:13 AM
Village_Idiot Village_Idiot is offline
Rep: 75 Posts: 238
10m sounds like a long time to get out of the hole. A lot of folks who run flats boats in TX talk about getting up on plane within a boat length.
You might check out the cat/tunnel design in the Flatscat - it is engineered to deliver water to the prop while the prop is running above the surface of the water. This is done with a reverse angle on the sides of the tunnel (quite the opposite of what you see on most factory pocket tunnels). www.flatscat.com
Also, to combat ventilation problems, stick with a prop that has a large blade area (swept blades) and a lot of cupping. Several prop builders along the TX/LA coast specialize in these types of props. Several I can think of are Louie Baumann www.baumannprops.com and Powertech www.ptprop.com, as well as www.propgods.com.
When it comes to standard factory props, four-blade props generally work better on tunnel hulls because they deal with the ventilation issues better. With that being said, I just replaced a 4-blade Trophy Plus prop on a tunnel hull with a Baumann 3-blade Blaster prop and it made a world of difference in holeshot and overall performance. The Blaster is a much better prop for that particular application. I think the main difference is in the cupping.
Old 07-17-2008, 10:36 AM
Baywolf's Avatar
Rep: 21 Posts: 33
Village, your right, a hole shot in a boat length, I have a 21' with custom cavitation plate that, (when you hit the throttle) the transom lunges up out of the water alot like a hoovercraft might, which means it can lift itself out in less than the boat length, but I meant, 10m to when it is fully plained, and the tunnel becomes un-necessary, or mostly skimming the top at 35-40mph or so. I calculated the amount of water in that tunnel in about the boat length, and was trying to pressurize it, then removing the drag after it was on plain, which would take about 10 meters, but the hole should be seen alomost instantly.
!!!!!DRIVEN!!!!!
Old 07-17-2008, 02:09 PM
Baywolf's Avatar
Rep: 21 Posts: 33
Someone said something on a different forum about batmans boat so drew this thing, note the tubes for the torpedos, hydrofoils, tunnel for shallow draft, retractable suspension system, retractable keel. You just need to picture it all with carbon fiber and nano's.
!!!!!DRIVEN!!!!!
Old 07-19-2008, 07:00 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Can I ask a stupid question? Why it is so important to get up on plane in such a short distance? Is it because you need to be on plane to get the propeller high enough to avoid damage when running fast in shallow water?
Kenneth Grome
Old 07-23-2008, 01:05 PM
Rep: 75 Posts: 238
Sometimes you just have a small area of deeper water, say 18 inches, maybe a half-acre or less, that the boat will run in, and jump up on plane in. There may be hundreds of acres of shallow water around you, say 10-12 inches deep. Your boat will run in 10 inches of water but needs 16 inches to get up on plane.
Sounds like an iffy scenario, but I've been in it often enough to make a quick holeshot well worth it to me. Having a boat jump up 'out of the hole' in a 20-foot distance or less is good insurance when running coastal flats or shallow rivers, where water depths of less than a foot may be the norm rather than the exception.
Old 07-23-2008, 06:48 PM
Rep: 287 Posts: 719
Thanks Village_Idiot, now I understand (I think) -- but let me ask this *theoretical* question just to be sure I got it right ...
If I design a boat that doesn't need any more depth to get onto plane than it already drafts when sitting at a dead stop, this would be a "good thing" in terms of moving around in such shallow waters, right?
In other words, if my design were to draft only 4-6 inches of water while the engine is off, and if I could simply start the engine and accelerate from a dead stop until the boat eventually gets onto plane -- all in the same 4-6 inches of water -- then I might have a boat the shallow water fishermen along the Gulf Coast will appreciate.
Is this correct?
Kenneth Grome
Old 07-28-2008, 08:14 AM
Rep: 75 Posts: 238
Yes, that is correct.
Many of those TX flats anglers are used to drifting in less than a foot of water and running in 8 inches or less, so there you have a target to shoot for.
FWIW, I run a 25-foot flat bottom tunnel hull with a 60-inch bottom width. It drafts 8 inches at rest, plus about 6 inches of prop and another 3-4 inches of skeg. When on plane in deep water, it probably drafts around 16 inches. However, when running up on a flat or submerged sandbar as speed, the compressed water raises the boat so that the bottom of the boat is almost level with the ambient surface of the water, leaving me with a "dynamic draft" of 8-10 inches of prop/skeg. If you've done much running between deep and shallow waters with a planing hull, you'll know what I'm talking about. Airboat pilots have much experience with this phenomenon - and it is why their boats perform much better in a few inches of water as opposed to deep water.
Good luck designing a planing hull that drifts as shallow as it runs.
Old 07-28-2008, 10:24 AM
Rep: 287 Posts: 719
Many of those TX flats anglers are used to drifting in less than a foot of water and running in 8 inches or less, so there you have a target to shoot for. Good luck designing a planing hull that drifts as shallow as it runs.
Actually I already designed it months ago, I was just hoping I had designed something that's actually useful and possibly also desirable ...
This is a small, very light (probably 350 pounds with engine) 15' by 5' flats boat designed to be powered by an inboard engine installed beneath or in front of the center console (not shown yet). 10 HP should make it plane with a light load and 20 HP should make it plane fast(er).
The waterline shown in these drawings is 4 inches draft at 750 pounds displacement so there's 300-350 pounds of payload capacity in this boat before it starts drafting more than 4 inches -- and at 6 inches its displacement is 1250 pounds, so there's still enough capacity for several people plus their gear even at 6 inches draft.
The trick to this boat is that the prop is located completely above the bottom of the hull, so it doesn't draft any more whether the engine is running or not. It uses a surface drive propeller to take advantage of the fact that it will be running in aerated water sometimes too.
By keeping the prop above the bottom of the hull at all times it will never get damaged, nor will you ever have to worry about adjusting the prop or engine for different water depths. And since you can run the boat at full power in such shallow water with no risk of prop damage, there's no need for a hole shot any more. If you're drifting in 6 inches of water and you want to go somewhere else, all you do is start the engine and go!
With no need for a hole shot there's no need for any excess "hole shot horsepower" either. This means the boat can use a MUCH smaller engine and still go everywhere any other flats boat can go ... but the guys who own these will save on fuel.
Here's a picture of how I superimposed a ZF Surface drive mechanism onto my design. I had actually created the design before I did this superimposition, so it was a pleasant surprise to learn that what I had designed so closely matches the ZF's dimensions:
I'm not going to use a ZF drive of course, they cost too much and I can accomplish the same thing with a much lower cost traditional prop shaft in a tube.
The whole idea of this boat is economy -- not only during construction but while the boat is in use. That's why I spent a lot of time considering everything about this boat that I could think of. Things like avoiding the need for propeller adjustment by designing the hull to regulate the depth of the water hitting the prop means I can avoid the cost of an adjustable propulsion system. This saves money and keeps both production and retail prices low.
Inboard engines can be had for 1/4 the cost of outboards. They may not make the nice sound of a 4-stroke outboard but with a custom muffler they are no noisier ... and they can be fixed cheaply any lawnmower shop.
There is one really nice feature about this boat that does not exist on outboards, too. With the engine installed in the middle of the boat, the entire transom area is completely free from obstruction. This means you can walk all the way around the boat when fighting a fish and nothing will get in your way ...
Granted at only 15' by 5' this is not a very big boat, but I think it may be big enough for three people, and I'm sure it is big enough for two. I also designed a smaller 12' by 4' version although this may be pushing it in terms of what shallow water fishermen will tolerate as far as small size is concerned. Then again, a 12x4 version might be ideal for those who almost always go out on their own without a companion.
I lived in Texas before, and I know that some of the 'good ole boys' there are into power and speed ... so I'm not sure a 15x5 flats scooter with such a small engine would attract them even if it performs well. What do you think?
Kenneth Grome
Old 07-28-2008, 10:41 AM
Rep: 756 Posts: 3,328
What would keep the tunnel from feeding the prop air?
With the scoop setup you propose Air might be entrained at a very low speed and propulsion would cease when the prop is unable to get even one blade wet.
Sounds like time for another model test.
FF
Boat design wanted- Ocean-worthy V-hull Skiff Climberb9 Projects & Proposals 4 08-08-2007 02:26 AM
Catamaran flats boat design bhaines Boat Design 1 09-08-2005 06:59 AM
Plans for a 15'-18' flats skiff Archive Powerboats 2 09-04-2004 08:33 PM
help wanted on take apart skiff design scubadude12 Boatbuilding 9 07-08-2004 09:29 AM
Tunnel Design help for Flats Skiff DanAyo Boat Design 13 10-29-2003 03:04 AM
