| Flat bottom, lwl/Tc ratio? Are there any major drawbacks from having a flat bottom (albeit slender lwl/beam of 8) at considerable draft please? By considerable, I mean a double ended vessel that displays a lwl/Tc of approximately 17. The Bwl/Tc would be 2 for minimum WSA and plenty of rocker. Sound confusing? Coinsider a long slender deepish draft Bolger to get a better picture. I like the idea in terms of construction but would like to know if there are major hydrodynamic no no's associated with this idea. Stability is fine as I'm hanging a large fin and bulb off her. If the corners should be rounded by how much please? Thanks for your time and trouble, Guillotine Racing. |
| I'd suggest that you make lists of all the advantages and disadvantages of a flat bottom on a boat such as the one you contemplate. If I did that, the flat bottom would not make it past the first draft.
| Flat bottom boats behave well only with low displacement. Even then, they pound quite a lot. Sailing sharpies when heeling, act as a vee hull. I don't see any advantages to a deep draft flat bottom boat. |
| About Flat Bottom Boats.....? | jfnewell1965 | Powerboats | 9 | 12-05-2005 10:03 AM |
| Need a design for a flat bottom boat | AliBaba | Boat Design | 4 | 04-29-2005 06:40 AM |
| Longitudinal stringers or Transverse ribs for flat bottom | dick stave | Boat Design | 1 | 02-13-2005 07:03 AM |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
| Flat Bottom Boat | Marsh Man | Open Discussion: All Things Boats & Boating | 9 | 05-18-2004 03:01 PM |
