Old 05-07-2010, 12:25 PM
jnwaco jnwaco is offline
Rep: 10 Posts: 23
Flat Bottom design question from a simpleton
Alright, I belong to a bowfishing forum and we're all flatbottom (give or take a few percent deadrise) freaks. Airboats, fan boats, tunnel hulls, etc...
A question came up as to what effect on performance the angle of the sides to the bottom has on a boat. We noticed some flatbottom makers have almost 135 degree angle to the bottom and others are almost straight up at 90 degrees. Airboats seem to have cupped (out) or curved sides, etc., etc. Quite a few on the site have had custom flat bottoms made and a few of us are considering it. Truly custom from scratch boats.
I know that given the same bottom width, a larger angle will make for a larger beam, which we like. Most of the sought after or build hulls have at least a 60" bottom and many have 70-80" bottoms, and 90"+ beams.
Old 05-07-2010, 01:16 PM
Rep: 1493 Posts: 7,447
Flare, the angle you are describing, gives the boat more dinamic staibility. As the boat heels, the flare gives more floatation and the other side's weight pulls down. This makes the boat tend to right itself.
Old 05-07-2010, 03:53 PM
Rep: 10 Posts: 23
That makes perfect sense. Thanks gonzo! And thanks for the vocab lesson! The boating terminology is definitely a new language!
Old 05-07-2010, 06:38 PM
Yellowjacket Yellowjacket is offline
Rep: 292 Posts: 249
Airboats don't have ridges or fins on the bottom since they would trip and flip if they caught the bottom in shallow water or in weeds or junk. They have flared sides to insure that they don't trip and flip over when they slide sideways.
Old 05-07-2010, 07:09 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
Also flat bottom hard chine boats (that is the intersection of the side is a sharp angle and the bottom is flat across) are rated at a lower horsepower than a similar boat with rounded chines or a curved or vee bottom. The reason is simply handling. Flat bottom hard chine boats can be easily made to trip over their chine and flip, by too much power. This rule only applies to boats under twenty feet in length.
Also giving the sides some angle outward rather than 90 degrees (called dearise) allows them to carry heavier loads. As the boat is loaded the immersed volume (the part below the waterline) increases faster if the sides are sloped than if the sides are straight up and down. So as you load it, the boat sinks less vertically and you maintain more freeboard (the part above the waterline)
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 05-08-2010, 10:17 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Perhaps you misspoke/typed?...deadrise is the angle of the vee of the bottom from horizontal not the flare of the sides from vertical.
Old 05-08-2010, 02:19 PM
Ike's Avatar
Ike Ike is offline
You are absolutely right. I've got to stop doing this stuff when I'm too tired to see, let alone think.
Ike
Old 05-08-2010, 03:21 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
Umm, you might want to look up 'tumblehome' too.
Old 05-08-2010, 04:30 PM
Rep: 10 Posts: 23
Thanks for all of the responses. This helped a lot.
Old 05-09-2010, 04:39 AM
lewisboats's Avatar
Obsessed Member
Oh...to be sure. I seem to exist in that condition. 2 jobs...working 7 days a week 80+ hours. Besides my vacation I may see 5 days off a year. Gets OLD after a while. Seeing the light at the end of the tunnel though...just hope it isn't a train
Old 05-09-2010, 09:26 AM
Rep: 10 Posts: 23
One more question - what's the technical or nautical term for the crimp in the side of flat bottom boats? I think it's supposed to divert water away from the hull for a drier ride, and on thinner skinned boats, helps stiffen the aluminum a bit.
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
Question: Small flat-bottom boat VV Cephei Boat Design 11 05-29-2009 09:14 PM
Need a design for a flat bottom boat AliBaba Boat Design 4 04-29-2005 06:40 AM
Flat Bottom Boat Marsh Man Open Discussion: All Things Boats & Boating 9 05-18-2004 03:01 PM
