Old 02-17-2004, 06:21 PM
colinstone colinstone is offline
Rep: 10 Posts: 44
Fishtail or Schilling rudder
Hi,
I am building a 72foot steel replica 1920s dutch barge in NL and want to fit a rudder that is either known as fishtail or schilling. The reason it is called fishtail is that is horizontal profile looks like the vertical profile of a fish. The advantage is that it is operated through a 140 degree range ie 70 - 0 - 70. In the normal 35-0-35 range it operates as a normal rudder, but when hard over gives sideways thrust. That with a bow truster means that the barge can be moved bodily sideways.
Anyway, anyone out there got some formulae - size of rudder, balance ratio etc etc. Distance trailing edge of prop to leading edge of rudder etc etc.
To see the type of vessel see here - this is a 15m version being built at the same yard. http://www.euroshipservices.nl/stand...sp?PakketID=57
TVMIA.
Old 01-20-2005, 03:49 AM
Rep: 66 Posts: 640
Colinstone,
To my knowledge the range upto 70 degrees is combined with a large rudder area to be able to give a thruster-like effect. The fishtail profile is for better performance in the 35-0-35 range.
Regards,
Dutch Peter
Old 01-20-2005, 06:18 AM
Danger Mouse's Avatar
Danger Mouse Danger Mouse is offline
Rep: 10 Posts: 13
www.becker-marine-systems.com
These guys produce the original Schilling rudder. Check out the site or drop them an e-mail
Old 01-20-2005, 06:40 AM
Rep: 66 Posts: 640
Danger Mouse,
The becker system rudder is not the same as a fishtail rudder. With the fishtail rudder the horizontal profile looks like a fish, but nothing moving.
Dutch Peter
Old 01-20-2005, 08:18 AM
Rep: 10 Posts: 13
Thought this was a fishtail profile without moving parts. Maybe my link should have been more specific:
http://www.becker-marine-systems.com..._schilling.pdf
Old 01-20-2005, 01:29 PM
Rep: 66 Posts: 640
Sorry Danger,
I didn't look any further, you're right.
Dutch Peter
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 07:09 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 08:15 PM
Rudder Design and Broaching joebobb Boat Design 0 02-25-2005 09:43 PM
Schilling Rudder (Fish Tail) Design for 65' T Boat oakes Boat Design 4 01-08-2005 12:27 AM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 03:36 PM
