  #61
Old 01-06-2006, 06:53 AM
VladZenin VladZenin is offline
Rep: 7 Posts: 128
I was wrong putting the picture of a catamaran. Travelling wave propeller can be installed on any kind of vessels. Why do you think that the wave sheet is moved with fixed amplitude? It is well known that the amplitude of oscillation of the swimming fish and dolphin body increases from the head to the tail. It is easy to realize in a propulsion device (see picture). What do you think about efficiency this propulsion device? What a difference in exit velocity compared to the free stream velocity will be?
See also "How fast can we swim with a dolphin like propeller?"
http://boatdesign.net/forums/showthread.php?t=8257
  #62
Old 01-06-2006, 07:00 AM
Rep: 7 Posts: 128
Originally Posted by Guillermo
I knew about it. I am a geologist by my first profession.
  #63
Old 01-06-2006, 07:07 AM
Rep: 7 Posts: 128
Originally Posted by mrdancer
I would lean toward using a vertical wave (side-to-side) as opposed to the up-and-down wave. My reasoning is a more stable vessel, particularly at speed, where the bow has no extraneous input on its entry into the water. As for side-to-side wave motion, effect on vessel can be minimized with twin adjacent drives, each canceling the other and possibly enhancing overall output (think frog kick). I think this would be much easier to design then an up-and-down system that produces no unwanted effects.
Have a look at the picture above. You can use this propulsion device in a vertical position too.
  #64
Old 01-06-2006, 11:27 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 312
The most efficient way to go from A to B is of course the transporter like that used in Star Trek. You just need some dilithium crystrals and a matter/anti-matter power source.
  #65
Old 01-06-2006, 02:31 PM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Vlad,
I think to make the travelling wave propulsion device practical, it is not appropriate to utilize an expensive, complex mechanical linkage. With mechanical devices, the more moving parts, the more places for failure. Perhaps a piezoelectric device (material bends with application of voltage). Such devices are already used to make fans for electronic devices. Another approach might be the use sheets of material that expand lengthwise with the application of electricity. Two such sheets bonded together would form a curve when only one is activated. Activate the opposite side and the curve reverses.
Aloha,
Jonathan
  #66
Old 01-06-2006, 03:43 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
...What do you think about efficiency this propulsion device?
My point is, you should be telling us. Nobody can just look at something and make a statement about its efficiency. At the preliminary stage, one's estimate necessarily has to be crude because you have to make a lot of assumptions to fill in for data you don't have. But I think you ought to make the effort to assess it.
To some extent, you specify what the exit velocity has to be. In order to power a given vessel at a given speed, you need a certain thrust. You can get the thrust with a high exit velocity and small exit area, or vice versa. The first step the designer has to do is chose these parameters and then see if the rest of the system is consistent with them.
Tom Speer
  #67
Old 01-07-2006, 03:39 AM
Rep: 7 Posts: 128
I don’t need to do this. Mother-Nature have done this for us.
  #68
Old 01-07-2006, 03:41 AM
Rep: 7 Posts: 128
Storm of applause
  #69
Old 01-07-2006, 03:43 AM
Rep: 7 Posts: 128
Originally Posted by JonathanCole
Vlad,
I think to make the travelling wave propulsion device practical, it is not appropriate to utilize an expensive, complex mechanical linkage. With mechanical devices, the more moving parts, the more places for failure. Perhaps a piezoelectric device (material bends with application of voltage). Such devices are already used to make fans for electronic devices. Another approach might be the use sheets of material that expand lengthwise with the application of electricity. Two such sheets bonded together would form a curve when only one is activated. Activate the opposite side and the curve reverses. Aloha, Jonathan
It is very interesting. Do you know performance attributes of a piezoelectric effect and expanding lengthwise with the application of electricity? What size of the expanding do you expect to achieve?
  #70
Old 01-07-2006, 05:01 PM
imagineer
Rep: 58 Posts: 436
There is a lot about this on the Internet. Here is a good departure point:
http://widget.ecn.purdue.edu/~CTRC/r...piezofans.html
Maybe this has relevance to Kjells fish tail propulsion as well. It seems that the piezo material flexes only a tiny amount with application of voltage, but also requires very little energy. Two pieces bonded as I said earlier could possibly flex and curve quite a lot due to the constraint of one plane on the other. In any case, the traveling wave may be better if it has low amplitude and high frequency as energy is applied most advantageously at high frequencies.
  #71
Old 01-08-2006, 02:47 AM
Rep: 7 Posts: 128
Yes, the piezo material flexes only a tiny amount with application of voltage. But it may be good for making toys.
  #72
Old 01-09-2006, 10:26 AM
kjell's Avatar
kjell kjell is offline
Rep: 17 Posts: 193
[quote=JonathanCole]
Maybe this has relevance to Kjells fish tail propulsion as well. QUOTE]
It is very interesting. I maybe can use this technique in small Tail-Jets for mini submarines.
  #73
Old 01-09-2006, 10:37 AM
imagineer
Rep: 58 Posts: 436
[quote=kjell]
Actually the illustration for the piezoelectric fan also suggests that the same flapping tail drive could be set up using electromagnetic coils on two sides of a magnetic material embedded in the base of the tail. This could be switched electronically and would eliminate the complexity of a mechanical drive which might be a very practical improvement both from a cost and durability perspective.
  #74
Old 01-09-2006, 11:56 AM
kjell's Avatar
Rep: 17 Posts: 193
This is an electro magnetic tail drive I was testing some years ago.
  #75
Old 01-10-2006, 06:09 AM
Rep: 7 Posts: 128
I see my travelling wave propulsion devices do not excite curiosity. I understand they are complicated and bulky. My ultimate aim was to disclose the idea of this kind of propulsion and show some specific engineering solutions. I think there are lots of physical principles that could be used for travelling wave generation. They should be uncovered when first boat models will show high performance attributes.
