Old 05-06-2011, 12:51 PM
Tim Hall Tim Hall is offline
Rep: 13 Posts: 57
First Design - Solo Canoe
Well, here's my first ever vessel design. Concept: solo canoe, general touring/weekend camping. Hope you guys here might take a moment to look over the lines and particulars, and give me a little criticism before I commit to drafting construction drawings. I'd really appreciate any feedback.
LOA 16' 4"
LWL 16' 0"
BOA 29.0"
BWL 26.4"
Bgnwl 24.0"
Draft 3.625"
Displ 276 lbs.
Cb 0.416
Cp 0.532
Cx 0.781
Cl 0.844
WSA 24.5 sf
WPA 22.1 sf
Ie 9.4°
Ix 11.4°
LCB 52.50%
LCF 51.30%
LCA 53.10%
H bw 16.6”
H md 11.5”
H sn 14.0”
Old 05-06-2011, 06:50 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
Nameplate capacity is usually calculated at 7" freeboard if I remember correctly. You are showing 6.9" so your listed disp. is about max. Not much room for camping gear. I'm a diehard backpacker, so when I trip by canoe it seems like total luxury- I can carry EVERYTHING (and usually do). Have you figured out the seat height if it's under the inwale. Just thinking an inch more depth to the whole thing might lead to a more comfortable and capacious boat. If you're planning on part decks, be sure to figure in you favorite hardshell cooler because it won't fit under the deck. Murphys Law.
Old 05-06-2011, 06:57 PM
Rep: 13 Posts: 57
Very good points, Phil. Thanks. I had in mind my weight, the weight of the boat, and thought "there's plenty of leftover displacement for gear/supplies." The size of the gear I neglected. And yes, it'll be partially decked.
I plan to place the seat as low as is possible to fit my feet under it for kneeling. Vertical placement shouldn't be an issue...been pondering this through the whole process.
Old 05-06-2011, 07:42 PM
openboater openboater is offline
Rep: 10 Posts: 27
It seems a bit narrow for a touring/camping boat. Old USCA and ACA Comp Cruiser racing specs allowed the widest beam at the 4" waterline to be no less than 14.375 % of the length. If I did my math right, your boat is around 13.75 %. Stock Class allowed 15%. I races a lot of these boats, and the Stock boats made much better campers and cruisers than the 'Comp Cruisers'.
Old 05-06-2011, 08:03 PM
philSweet's Avatar
Rep: 658 Posts: 621
Which brings up the question- Single bladed paddle or double?
Old 05-06-2011, 08:06 PM
Rep: 13 Posts: 57
It is definitely narrow by 'canoe' standards. My idea here was to design something in between canoe/kayak dimensions and paddling performance. My thinking is it'll still pack away quite a bit more (with easier access) than a kayak of comparable length...and probably close to equivalent of a solo 'camping' kayak. It's not intended for expedition.
Rep: 13 Posts: 57
I was thinking double. Dimensional issues with the mechanics of this? That's why I have the tumblehome and low freeboard.
Old 05-06-2011, 08:11 PM
philSweet's Avatar
Rep: 658 Posts: 621
Don't Know. I haven't done enough double blade paddling to comment.
Old 05-06-2011, 10:16 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Canoes and kayaks, at least in the US, are exempt from the federal maximum capacity regulations so a capacity on the nameplate isn't required.
Canoe manufactuers have different ways of determining capacity. Lincoln gives it as capacity at 6" freeboard. Some other manufactuers quote capacities but how they arrive at their figures isn't obvious. I wouldn't be surprised if someone came up with an arbitray 7" freeboard for as their standard for the common two-person "Canadian" type canoes.
Old 05-06-2011, 10:29 PM
Engineer
The shape is nice. I prefer it to your preliminary design of a few days ago.
Bear Mountain Canoe has some dimensions and hydrostatic information ontheir website for the canoe plans they sell as well as much reduced lines drawings. The Might be an interesting source of comparisons. http://www.bearmountainboats.com/_canoes.htm Click on "Details" under a particular boat's entry to see:
· Length
· Maximum beam
· Beam waterline
· Beam gunnel
· Bow height
· Centre depth
· Draft
· Displacement
· Wetted surface
· Weight to immerse
· Prismatic coefficient
· Weight
Metacenter height at 15 degrees is also available in normalized form on this page: http://www.bearmountainboats.com/compare_designs.htm Scroll to the bottom of the page to see the scaling used.
Old 05-07-2011, 07:59 AM
Rep: 13 Posts: 57
Thanks. I'm starting to really like where it's headed.
Bear Mountain Canoe has...
Yes, I've been studying every design I can find with some hydrostatic properties attached. Both canoes and kayaks. I've been going through the Bear Mountain catalog quite a bit. Also Nick Schade has tons of hydrostatic info about his designs on his website.
The big thing I haven't done yet is stability calc's. But otherwise the design seems to be falling within norms now.
SOLD Canoe Mold, Male, 12' solo road_warrior64 Boat Molds 1 04-13-2011 07:16 AM
Small Solo Canoe ideas banini_jeque Boat Design 3 08-20-2010 09:09 PM
Corsica 15 R A New Design for Solo Sailing Chris Ostlind Multihulls 25 07-27-2010 12:36 PM
Canoe Hull Design southernengenr Boat Design 64 08-03-2008 09:47 PM
Canoe Hull Design tostig Boat Design 2 11-15-2004 03:08 PM
