Old 03-21-2011, 11:09 AM
reddae reddae is offline
Rep: 10 Posts: 2
First build
Ok, so I am currently deployed for OEF, I have decided that when I get home I am going to start building a boat for a project to keep me busy and hopefully have a decent craft to use for fishing and recreation when I am done. I have been looking at hull designs and weighing those against when I want to do, here is what I have come up with.
I am thinking I am going to make a tunnel bottom boat with a flat deck that I can fish off of, my wife can lay out on, and my dog can walk around on. I will build the frame out of wood and use s-glass woven cloth and polyester resin from US Composites to form the shell. I am not sure what kind of motor to put on it, maybe just a trolling motor or a low horsepower motor. I don't really need it to be fast. If any controls are installed I will put the console just forward of the center line to offset the weight of the motor. as far as the size goes, I am thinking 6 feet wide and maybe 10 to 15 feet long.
This will be my first experience in designing and building a boat, but hopefully it will work out at least half-way decent. Again, it will be used for fishing and recreation.
Is this at least a decent idea or should I consider a better hull design? Any pointers would be great, I will be home in a couple months and want to jump right in to it.
Old 03-21-2011, 11:17 AM
Rep: 10 Posts: 2
Looking at motors, if I do an outboard I don't need any controls and I can just put a seat up front with the whole middle open for whatever I choose.
Old 03-21-2011, 02:09 PM
Rep: 670 Posts: 2,457
S glass is expensive , tight woven and not the best stuff for a homebuild small craft. ...e glass , woven and stitched is much cheaper, available, easy to work with and strong enough to handle any home build.
Do an Internet search for stitch and glue boats and you will find hundreds of pre engineered, stock designs. Many are well conceived, elegant and simple to build.
on Boatdesign net there are several well regarded small craft designers.
Further refine your requirements, then start a thread seeking input.
Old 03-21-2011, 02:13 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
A thought for you. https://www.boatdesigns.com/products.asp?dept=740
one more http://www.glen-l.com/designs/special/scooter.html
Where To Build? F.H.B. Boatbuilding 3 12-25-2009 10:15 PM
First new build StuartRB Wooden Boat Building and Restoration 16 04-15-2009 08:37 AM
new build thecopperdoc Sailboats 2 12-15-2006 11:11 AM
where to build wannabe Open Discussion: All Things Boats & Boating 5 10-08-2006 08:14 PM
First Build Alixander Beck Wooden Boat Building and Restoration 2 06-21-2005 01:48 PM
