Old 11-04-2008, 08:24 PM
PAR PAR is online now
Rep: 3125 Posts: 9,397
Epoxy will not burn by itself, it will distort, lose grip on substrates, caramelize, but not burn in the usual temperatures you see in a burning boat. If you hold a mapp gas torch to it (epoxy) it will smolder, change color, and even look like it's burning, but remove the flame and it'll just smoke and stop.
If you mix aluminum oxide with the resin as an over coating or in the laminate, you will dramatically reduce the "fire" risk. It also makes sanding it smooth a real pain in the butt. Also the aluminum oxide will act as a heat reflector if you use enough.
Log onto WWW.WestSystem.com and check out their user's guide and Has. Mat. labels. It covers the information you want.
Old 11-09-2008, 04:34 PM
diwebb diwebb is offline
Rep: 65 Posts: 120
Hi,
one thing you may want to look at are intumescent paint finishes. These expand and form an insulating non combustible layer when exposed to an open flame and are good enough to provide a one hour fire ratinjg under some building codes. That said, other contributore are correct that the hull material is way down the list of items to be worried about.
All the best.
David
Old 11-09-2008, 05:23 PM
Tom Hunter Tom Hunter is offline
Rep: 16 Posts: 9
I would try to understand her concerns. Do you have cabinets over the stove at home? Find out the clearance and see if you can match it in the boat. Can you put fireproof tiles behind the stove on the boat? I would take some small steps like that to show her you are listening to her concerns and addressing them.
Old 11-27-2008, 08:07 PM
messman messman is offline
Rep: 19 Posts: 29
If it really something that you need to address with her, you should be able to use something like this around the Gally area.
Chris
Fiberglass fire damage to a fiberglass boat Eagle Boats Fiberglass and Composite Boat Building 26 11-14-2011 11:17 AM
69 johnson 85 no fire shwnar Outboards 0 04-22-2008 12:48 PM
Boat Fire Videos Ike Open Discussion: All Things Boats & Boating 1 03-27-2007 08:36 PM
Vanguard Sailboats Fire Doug Lord Sailboats 1 02-23-2007 04:29 PM
back fire diversion Propulsion 6 08-01-2004 05:40 AM
