Old 06-18-2005, 10:47 AM
Jeffrey Jeffrey is offline
Rep: 10 Posts: 10
Finishing Hull/Deck joint
I'm looking into finishing the hull/deck joint to eliminate the rub rail.
The boat is laminated with Hydrex 100 vinyl ester resin skinned with mat and backed with 1208 +- 45* knitted fabric.... What material is best suited for filling the joint where the two halves meet, that will not pop off under normal use.
Thanks
Jeffrey
Old 06-18-2005, 11:29 AM
Rep: 1493 Posts: 7,447
Do you mean the hull/deck joint is backed with 1208?
Old 06-18-2005, 02:45 PM
Rep: 10 Posts: 10
Gonzo,
No, the first layer of knit fabric behind the gel is 1208.
Old 06-19-2005, 09:27 AM
I have done that kind of job. However, since you are changing the structural design, it would take either a recomendation from the original designer or someone who can calculate the changes. It is difficult to do without seeing the boat and having a laminate schedule.
Old 06-19-2005, 03:11 PM
Rep: 10 Posts: 10
Gonzo,
I'm not changing the structural elements in any way. The vinyl rub rail is purely cosmetic. It simply screws to the hull/deck joint. I just want opinions on what material is best suited to fill the seam that runs around the perimeter of the boat and possibly recontour some areas. The joint is NOT a shoebox fit. The hull and deck butt together.
Jeffrey
Old 06-19-2005, 10:13 PM
In that case, you can use an epoxy filler, prime and paint or gelcoat.
Hull joint extrusion Lew Morris Sailboats 3 09-09-2005 08:45 PM
Hull/deck estrusion Lew Morris Fiberglass and Composite Boat Building 3 09-08-2005 11:37 AM
Hull Joint Extrusion Lew Morris Boat Design 2 09-08-2005 11:06 AM
Joint methods JosephKeel Wooden Boat Building and Restoration 10 08-10-2004 03:13 AM
Crack in joint of two piece hull... ErikG Sailboats 5 04-07-2004 11:23 PM
