Old 05-05-2008, 08:32 AM
northerncat northerncat is offline
Rep: 9 Posts: 170
finding the lcg of a boat
i have just finished building a small 2.7m assymetric cat dinghy for my 40 ft catamran and im just wondering if theres an easy way for me to find its lcg given that i built it without plans from my head and yes a lot of guessgeneering went on as i couldnt find any plans to build from. thanks in advance for any assistance
sean
Old 05-05-2008, 06:35 PM
CTMD's Avatar
CTMD CTMD is offline
Naval Architect
Rep: 117 Posts: 196
If you've built it finding the LCG is easy (especially as its only 2.7m long) simply sit it on a single beam and move it backwards and forwards until it balances (I've seen yards do the with 40' cats too). Unfortunately I think your actually asking about the LCB. This will be much harder to calculate with drawings.
Chris Tucker Marine Design
Your Boat Your Way.
www.ctmd.com.au
Old 05-06-2008, 05:08 AM
Rep: 9 Posts: 170
Does the motor need to be on for this to occur? if i make some drawings in autocad can i calculate the lcb then?
sean
Old 05-06-2008, 06:36 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 311
Put it in the water. The LCB and LCG will line up. Take a 10 or 20 pound weight and place it in the dinghy- find the place to put the weight which does not make the dinghy go bow down or stern down, but just sinks straight in. That is the LCB/LCG.
Old 05-06-2008, 06:37 AM
CTMD's Avatar
Naval Architect
Rep: 117 Posts: 196
I'm assuming you are trying to work out the LCG to set up a lifting system, is this correct?
1. Find the ballance point and measure it as a distance from the transom.
2. Weight the boat (a couple of sets of bathroom scales will do for this job).
3. Weight the engine.
4. Do the following calc.
Total LCG = (hull lcg) x (Hull weight)/(Hull weight + Engine weight).
This assumes the outboard LCG is right above the transom, which is probably close enough. If you have any other items to add they can be included in the calc as well.
Your Boat Your Way.
www.ctmd.com.au
Old 05-06-2008, 10:05 AM
Rep: 9 Posts: 170
yes i want to know so that i can place lifting points for hauling up out of the water
thanks for the info sean
Old 05-06-2008, 01:16 PM
Member
Rep: -33 Posts: 951
Plot the area of each underwater section on a cardboard graph. Cut out the graph and balance it on a pencil. That is your LCB, where your LCG should be, if you want it to float level..
Brent
Old 05-11-2008, 06:12 AM
Rep: 9 Posts: 170
http://www.hostmybb.com/phpbb/viewto...=0&mforum=easy
ive put a couple of photos up here of the boat for anyone interested
Old 05-20-2008, 05:02 AM
Rep: 9 Posts: 170
ok i have a few things that i would like to throw out there regarding my new dinghy it doesnt quite have the bouyancy that i would like so i am thinking of glueing 100mm of polystyrene on the bottom and sides of the hulls to increase bouyancy and then shaping it and glueing some doorsking ply over this and then glassing this back on to the original hulls, does this sound reasonable?
sean
Help finding cat survey boat builder nyriyadh Boatbuilding 2 01-21-2008 02:51 PM
finding hull blisters -boat has been on land for several years naturewaterboy Materials 5 10-08-2007 08:36 AM
LCG in RIB Mat-C Powerboats 3 07-10-2007 02:50 AM
finding CLR while boat is in water? francis k Sailboats 13 10-31-2006 09:02 PM
Need Help finding good alumunim boat builder here in Thailand waterpump Boat Design 7 10-16-2006 02:03 AM
