Old 08-08-2007, 02:11 PM
Mcgyver Mcgyver is offline
Rep: 10 Posts: 3
finding the arc between two points
Im starting to build a hydroplane from the 60's (sporthydro) that I found on the net, and I can't figure out how to find out the curve of the BOWPLATE. I have all of the dimensions that I need but cant figure out the curve. I know I can just wing it and get something close but I want it to be a little bit more precise. is there a more precise way of doing this or do I have to guess. I have also clipped a picture from the plans so you can see what I'm talking about
Please Help
The New Guy
Mcgyver
Old 08-08-2007, 02:28 PM
LP's Avatar
LP LP is offline
Rep: 370 Posts: 641
Without going into detail, I just drew it up at a 62" radius.
LP
God bless the open minded people of the world. LP
Old 08-08-2007, 02:35 PM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Use a batten to create the curve, using the measurements given on the blueprint.
Pericles
Old 08-08-2007, 02:36 PM
Rep: 10 Posts: 3
So string and a pencil is the simplest way to do this? if there is a better way to do this, can you point me in the right direction?
Mcgyver
Old 08-08-2007, 03:23 PM
Previous Member
Rep: 0 Posts: 0
take the beam, and divide by 3
then take the crown height and mutliply by these factors
at 1/3 beam out from centre, multiply height by .8818, and 2/3 out by .5393
draw straight line between outside ponts and divide into the thirds, now square up and mark the heights you obtained , I do all my decks this way, if there are 40 beams I do each and everyone separately, makes very fair deck and beam,
you can then use a batten to draw in the line from points or do it in rhino or something
is this what you are wanting?
Old 08-08-2007, 03:33 PM
Previous Member
Rep: 0 Posts: 0
here in rhino
Old 08-08-2007, 03:48 PM
Previous Member
Rep: 0 Posts: 0
here it is split up, it is a very accurate and fast way
Old 08-08-2007, 04:23 PM
Michael Chudy Michael Chudy is offline
Yacht Designer
Rep: 16 Posts: 39
If you want the math, here it is.
To find the radius of an arc when you know the height and the length:
You know the height of the arc = 4.5"
The length is 48 " minus twice the length of the opposite side of the triangle whose adjacent side is 3" and angle is 15 Degrees.
Opp = Adj * tan angle. So Opp = 3" * tan 15. Opp = .804"
Length = 48 - (2* .804) = 46.392
Using Pythagorean theorem:
Radius = (4h^2 + L^2) / 8h
Radius = 62"
All this information and more is available online at
http://mathcentral.uregina.ca/
Have fun,
Michael
Old 08-12-2007, 02:01 AM
Rep: 10 Posts: 3
Thank you very much for your help guys. I got the desired arc for the bow plate and it came out perfect.
Thank you
Mcgyver
Old 08-14-2007, 11:23 AM
BWD BWD is offline
Rep: 128 Posts: 228
Glad the deck arc came out right.
Wanted to ask if anyone has used the method from Gougeon's book, getting ready to do so myself.
Very simple, draw circle with radius equal to deck camber, measure arc heights above diameter, transfer to template/stock and spring batten. Seems straightforward, but no reason not to ask before cutting...
Old 09-13-2007, 04:38 AM
SkipperSki SkipperSki is offline
Rep: 10 Posts: 11
Please Help
The New Guy
Mcgyver
Mcgyver,
I assume the picture is from a magazine, the easiest way is first determine the scale of the drawing, using the 6" dimension, on a scale ruler it's say, 3/8" which is a half foot of 3/4" scale.
Now tape the picture to a sheet of paper, and using only a drawing compass, pick two points along the arc. place the compass on one point, and scribe a 180 degree right arc, perpendicular to the arc, place the compass neddle at the intersection, and scribe a 180 degree left arc, the intersection points of the two scribed arc's, place a straight edge on these points and draw a line, out on the drawing paper, this drawn line is perpendicluar to the design arc, do the same at a wider point of the design arc, this second line drawn to intersect with the first, is the vertex of the designs radius, measure the design radius from the found drawing scale. Or draw it out full size on your material.
Old 09-13-2007, 08:54 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
Most of the above methods will give an adequate answer.
The formula is: r = 4(h^2) + (c^2)/ 8h
r = radius of arc
h = height of arc = 4 1/2
c = span of arc = 48
So the radius of your deck beam is 64.55"
If the span is far greater than the height, a close enough answer is r = c^2/8h which give 64". close enough and easy enough to remember.
Tom Lathrop
Old 09-13-2007, 10:35 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
I take it no one reads the entire post...he already has the darn thing done!
Old 09-13-2007, 01:23 PM
Rep: 10 Posts: 11
Aye, Aye, Mate !
But someone may learn from it next year !
The compass method is fool proof, when doing a boat part copy/restoration.
by drawing out the arc full size, and find the center of the arc/circle (s)
Old 09-13-2007, 01:41 PM
Aye Lewis, but knowing the simple formula will work at small scale on paper or at any scale next time anyone wants to do this. The true mensuration formula from a math book is much more involved but this one works well enough.
Of course if anyone just likes to plug numbers into an internet table, just look here:http://www.handymath.com/cgi-bin/rad2.cgi?submit=Entry
Also kicks out the length of the arc.
Good knowledge never wasted.
Tom Lathrop
Rhino - Triangulate 3d points? AlexDim Software 11 07-04-2007 08:47 AM
Burnt Points FISHERMAN1 Electrical Systems 8 06-04-2007 08:13 AM
Asking Opinion & Comment in Learning Naval Arc. Syukri Open Discussion: All Things Boats & Boating 0 03-22-2007 12:16 AM
points cloud Mirko Software 10 06-25-2005 07:59 AM
ARC Marine Everyman martin Pedel Wooden Boat Building and Restoration 2 08-16-2004 06:35 PM
