| Find the waterline Will one of these freeware programs be able to find the waterline of a 24' boat if I have all the lines and weights? thanks:Or is there any easy way to find the loaded waterline if I have all the lines ![]() |
| I think they should. Inputing lines, just run the hydros and search within them for a displacement equal to the sume of known weights (I'm asuming 0 trim). If you know the longitudinal position of all COGs for all weights with precision, you can even find the proper trim by running hydros for several trims and find which one provides the center of buoyancy with the same X than the COG. if trim is small we can asume this as being true (If the program uses a fixed to the boat reference system -most NA programs work like this- when B is right in the same vertical as G they do not have exactly the same X). Cheers.
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| how to find waterline for desired displacement? | pulsar | Software | 8 | 01-04-2008 12:21 AM |
| Confusion Below the Waterline | Texas Boater | Wooden Boat Building and Restoration | 2 | 05-20-2006 03:40 PM |
| repainting Thompson, below waterline | bigfootnampa | Wooden Boat Building and Restoration | 3 | 07-06-2005 09:53 PM |
| formula for finding waterline? | Baldur | Boat Design | 13 | 06-17-2005 04:21 PM |
| designed waterline? | huw | Boat Design | 3 | 06-05-2004 12:29 AM |
