| The Sadler 24's and 29's were the first and as far as I know only, sailing monohulls in their size range that have positive flotation built into their two part hull construction by injecting a closed cell foam between the inner liner and outer hulls-- A yacht is not defined by the vessel but by the care and love of their owners --- |
Porta |
| Sadler boats have a very thick foam core that provides enough flotation to make them unsinkable. It takes a lot of interior space, but is a simple solution. Inflating bags and other systems make little sense. They would need a huge amount of maintenance and care. Also, the cost would be very high, just price a self inflating life raft, which is made by the thousands. The bags in a boat need to be custom made.
__________________ Gonzo |
I wish I knew which boats would have this foam core, and which did not. BTW. four wheel drive vehicles often run engines underneath water to cross rivers and such.http://youtu.be/_lBakSKg8cA (You can see the red snorkel top sticking up past the roof of the car) |
| As I prev. posted Sadler are the only monohulls in their size that i'm aware of that has this positive flotation feature. If you look them up they posted their test results when flooded and making use of the positive flotation feature-- the boat seems to still be functional as a sailing vessel and was able to sail back to home port. A great feature for blue water work in a smaller yacht for sure. Your yacht becomes your lifeboat. |
P. |
I don't know about materials though, Such as, what materials will deteriorate in salt water, and maybe even get eaten by sea life. I am considering a wrap around that attaches to the upper 1/3rd of the hull by pulling it underneath the boat, stretching a boot around the hull and tying it off to the railings, bulwarks, bowsprits, whatever, so that it is snugged tightly against the upper part of the hull. Then when it inflates, it sticks out along the entire perimeter like a life raft stretched around the hull, or like a life raft with a sailboat stuck in the middle of it. Yes, it will have to be custom made, but won't be too difficult with most hulls I've seen. The flare of the hull itself keeps it from coming off over the top, and it can be tied in place to keep it from falling off. The beam to length ratio stays the same that way, and the only thing to get in the way is an outboard, maybe a swimming ladder, and maybe the rudder, so maybe there won't be as much lift at the transom. Each boat is different so it HAS to be custom fitted, but I want to minimize the drag and maximize inflation which should be easily accomplished by essentially turning it into an inflated bulwarks. The problem is that it should be sealed to keep out moisture so that it doesn't trap moisture, or it should only be installed when the boat is going out for a cruise. |
The whole thing will come down to whether or not you want your boat to be your life raft, and what you will do to keep as many of your components safe/salvageable when you get back to home port. |
| Military vehicles have been using snorkel systems for decades; in salt water too.
#25
| I wonder if there is a way to make my safety device non-patentable, as I believe that most safety devices should be treated. I want people to expound on my ideas, not feel like I might threaten them with lawyers if they make a safety device that's works out better. ![]() |
#26
| Patents are voluntary. There is no Law that prevents an inventor from putting his work in the public domain
#27
#28
| Back finally | Stumble | Open Discussion: All Things Boats & Boating | 4 | 05-09-2011 07:43 PM |
| 24 Hp Mudmotor Finally Finished | muddin redneck | DIY Marinizing | 24 | 06-05-2010 10:03 PM |
| I finally made it home! | Distans 52 | Open Discussion: All Things Boats & Boating | 21 | 01-08-2009 07:58 PM |
| Things Are Better And Worse... | Sean Herron | Boat Design | 3 | 01-06-2008 02:31 PM |
| All Things Must End | artemis | Open Discussion: All Things Boats & Boating | 4 | 12-31-2007 12:22 AM |
