Old 07-12-2007, 09:48 PM
delmarrey delmarrey is offline
Rep: 10 Posts: 5
Fin Keel Technology
Some where recently I read and article, I believe a magazine article in a .pfd format, that showed by adding a 15 degree wedge to the front of a fin keel right at the hull joint, that it improves the drag ratio.
I haven't been able to find that article again and was going to use their formula for my IOR designed vessel.
Can anyone point me to that article or another that would has the same info??
Thanks…………………………_/)
Old 07-13-2007, 09:03 AM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
Keel design issues
Tom Speer
Old 07-13-2007, 07:26 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Maybe also this,
http://www.proboat-digital.com/proboat/200506/
click on "Content" and the the article starting on page 76.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 07-13-2007, 11:47 PM
Rep: 10 Posts: 5
Originally Posted by Raggi_Thor View Post
Maybe also this,
Yes Sir, That's it! Just what I was looking for. Thank you very much. I'll bet I can find it in my favorites now by the above address. I must have over a thousand links saved and catagorized but didn't rename this one to ID it well enough.
Thanks again!
..................................................................._/)
Old 07-14-2007, 04:34 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Wedge on keel
The FA 18 Hornet has a rather more extreme version of such an arrangement for its wings. http://en.wikipedia.org/wiki/Image:F...ue-Diamond.jpg
Perhaps the F 16 has a better shape. http://en.wikipedia.org/wiki/Image:F...ing_Falcon.jpg
Pericles
Old 07-14-2007, 06:14 PM
Raggi_Thor's Avatar
Yes, but sailboats operate on more variable angles of attack
www.MBOATS.no
Old 07-14-2007, 06:17 PM
Raggi_Thor's Avatar
Originally Posted by delmarrey View Post
...I must have over a thousand links saved and catagorized but didn't rename this one to ID it well enough.
Most info i search able, but maybe not ProBoat, because the pages we see are pictures, not text?
Just remember the very important point: There is no good changing the planform of a keel (or other foil) if you can't keep the correct profile in all sections.
www.MBOATS.no
Old 07-14-2007, 11:01 PM
Originally Posted by Pericles View Post
The FA 18 Hornet has a rather more extreme version of such an arrangement for its wings. ...Perhaps the F 16 has a better shape.
The fighter leading edge extensions are for a completely different reason and work in a completely different manner. They exploit separated flow - shedding a vortex that improves lift at high angles of attack as it flows back across the wing. They have sharp leading edges to promote separation as the angle of attack increases. This is not the way to minimize junction drag due separation of the body boundary layer approaching the leading edge.
The dillet is also a leading edge extension, but its purpose is to eliminate separation at low angles of attack. It is small and rounded. This picture of a Boeing 767 horizontal stabilizer with a dillet shows it from a different angle than the planform sketched in the article above. You can see that it is very different from a fighter's leading edge extension.
Tom Speer
Old 07-14-2007, 11:36 PM
Rep: 1623 Posts: 1,483
Hydro dillets tend to be shaped different then aero dillets. Here is an oblique shot of one, there are very few true beam shots available.
where would you put a fin? Frosty Boat Design 15 03-02-2007 02:49 PM
Fin Keel to Lifting Keel on my Columbia 28 SteveWinNH Sailboats 5 04-05-2006 06:35 AM
Teardrop End Plate On NACA Flat Bottomed Fin Keel ?? RDKinard Sailboats 34 01-14-2006 01:40 PM
keel fin thickness usa2 Sailboats 14 12-05-2005 04:22 AM
Fin Keel CBrown Sailboats 7 08-10-2004 08:06 AM
