Old 12-24-2011, 03:11 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...stop thinking....
Old 12-28-2011, 02:01 AM
Stumble Stumble is online now
Rep: 599 Posts: 1,085
Assuming the hull could take it, and could be sealed it would actually be more advetagious to remove the air, and not replace it with anything. Vaccume is lighter than helium.
Old 12-28-2011, 03:30 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Space
Originally Posted by kapnD View Post
Lead in the keel, helium in the mast?
How about a helium filled kite attached to the top of the mast?
This thread got me wondering about the possible uses of helium and the necessary storage of bottles associated with its use, and the question that hit me is, is an empty helium tank heavier than a full one?
Why arent the tanks stored on the ceiling instead of the floor?
Happy Holidays!
why not go boating in space then anything could happen ! weightlessness so dont need a lead keel thats save a lot of weight . HULLS could be any shape , no skin friction to ponder of worry about ! would have to have enormouse sails to harness the solar wind . would always be plain sailing !
Making beautiful boats is a passion never a chore !
Old 12-28-2011, 07:07 AM
ldigas ldigas is online now
Rep: 43 Posts: 160
Originally Posted by michael pierzga View Post
For measurement purposes we lighten her up for measurement with an imported, South African built, anti gravity tractor beam.
Cheap to operate and gives you a real edge on the race course.
This picture is beautiful
Old 12-28-2011, 01:28 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Where did you get it - still a highly top secret weapon here under development by the neo nazi AWB movement in partnership with the Yankee KKK....
Wynand
A scatterling of Africa
Old 12-29-2011, 06:42 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
I filed patent on helium as used in augmentative breast implants. No sag and a built in leak detector, if voice starts to sound like a duck, leak indicated.
Steve
Old 12-30-2011, 01:35 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Ahhhh, but mass remains unchanged.......
-Tom
Old 12-31-2011, 12:13 AM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Originally Posted by Collin View Post
Weird thought I had about a way to decrease the weight of racing boats...
Since racing sailboats are stripped down to nothing and you have a lot of interior empty space, couldn't you seal it off and fill it with helium? You could reduce boat weight by thousands of pounds.
Seems like it would work??
A thousand cubic feet of air is said to weigh 80 lbs.
Helium, IIRC, weighs about a third as much as air.
So, at best your going to get a 53.33 lb reduction of weight for every thousand cubic feet filled with helium.
With nasty, dangerous hydrogen that reduction goes up to about 70 lbs per thousand cubic feet.
This weight reduction would easily be off set by the crew having to wear air tanks whenever they go below.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
Old 12-31-2011, 03:51 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Why waste helium on boats. Airships can travel at the speed of the wind with no engines - much fast than any yacht, and no waves !!.
  #25
Old 01-04-2012, 04:48 AM
masrapido masrapido is offline
Junior forever
Rep: 281 Posts: 258
That was the only serious suggestion so far Mr. Watson...
My signature is bigger than yours...
instead of lifeboat, how about Helium balloon? Squidly-Diddly Boat Design 22 10-05-2010 12:26 PM
USA-Technical Details-Helium used Doug Lord Multihulls 107 05-15-2010 12:47 PM
HELIUM Chris Ostlind Open Discussion: All Things Boats & Boating 5 04-07-2010 05:00 AM
filling cracks idaboat Materials 3 03-01-2010 11:22 PM
Foam filling alluminum hulls Guest Materials 12 12-23-2004 11:03 PM
