Old 10-04-2007, 08:06 AM
georgiahemi georgiahemi is offline
Rep: 10 Posts: 25
fiberglassing PVC pipe??
I am making some rod holders for a jon boat I just built. I was planning on fiberglassing in some normal plumbers pipe to make this. Will the fiberglass or epoxy damage these plastic pipes?
Old 10-04-2007, 09:07 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Won't damage the pipe but likely won't stick very well either. You'd have to roughen it up pretty good to get it to stick. The epoxy won't ever bond to the plastic so you're relying on the mechanical bond (weaker) to hold it in place.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 10-04-2007, 10:16 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
If your boat is polyester, you could glass in the PVC with polyester and get a good bond. As said, roughen the surfaces of boat and pipe ---- no matter which resin you use. The pipe to use could be what's used for kitchen drains--- 1 1/4" with a flange at the top. This will protect the top edges, be the right size for pole handles, and it won't be as thick either. You may even find a darker color than white, like gray.
Alan
Old 10-05-2007, 02:53 AM
nero nero is online now
Rep: 112 Posts: 624
Use pipe cleaner (sold in the plumbing supply department).
I have been using some white PVC pipe to make fillets with. After each use I wipe it down with paper towels. Forgot to do this one time. Will testify that the bond is more than mechanical and that it had to be sanded off. Chipping would not make the resin pop off.
Old 10-05-2007, 03:49 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Yes - excellent bond to PVC pipe - even if it isnt roughened. Will be stuck to it for a loooong time. Even with movement and stress, it holds up very well i have found out.
Old 10-05-2007, 06:05 AM
bart streb bart streb is offline
Bart
Rep: 10 Posts: 25
I actually used normal 2" white pvc for a drainpipe from the cockpit floor to the drain site above the waterline in a fiberglass boat. 3 years later, she is still afloat! I used West System Epoxy.
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 10:23 AM
150mm pvc pipe jgfish Materials 17 01-23-2007 08:16 AM
?? about compression pipe in a mast!!! MarioCoccon Sailboats 3 04-26-2006 07:42 AM
Pipe/tube bender Dallas_B_ Open Discussion: All Things Boats & Boating 2 08-26-2005 07:05 PM
Pipe Rudder Bob Smalser Boatbuilding 3 02-18-2005 02:01 AM
