Old 12-15-2009, 06:03 PM
bwhntrjsh bwhntrjsh is offline
Rep: 10 Posts: 2
fiberglass poly
Hello all new to boatbuilding and this forum hope someone could help. Does anyone know of a way to epoxy a peice of 3/8 to a fiberglass flat bottom. I want to build a fiberglass boat w poly (airboat poly) but dont want to drill holes because it would be a sealed deck.
thanks josh
Old 12-16-2009, 05:13 PM
PAR PAR is online now
Rep: 3125 Posts: 9,397
You need to define your questions more. For example a 3/8 what? Lets assume you mean an inch. Okay, of what? Lets assume you mean plywood. Drill holes in what, the plywood, the boat hull? Why would you drill holes and why couldn't these holes be filled if you had to drill holes?
As you can see there are more questions and assumsions about your questions, then I have answers. So, if you could refine your questions, maybe tell us about your boat, what it is, how it's made, what you're trying to do in more detail so assumsions can be avoided.
Old 12-17-2009, 01:19 PM
Rep: 10 Posts: 2
it will be a fiberglass hull flat bottom i want to put a 3/8" polymer,slick plastic to slide across water very easily . the polymer will need to come off at some point to replace it. For an air/fan boat.
Old 12-17-2009, 06:51 PM
If you'll be using the usual high modulus plastics as everyone else, then you'll have to fasten them, as these plastics don't glue well, especially under the abuse they'll see.
Poly Pontoons? rj12c Multihulls 4 06-01-2009 03:51 PM
9 month old poly resin pescaloco Fiberglass and Composite Boat Building 16 02-11-2008 09:21 AM
GRP, Epoxy or Poly...? cuorefocoso Fiberglass and Composite Boat Building 12 01-10-2008 07:46 AM
epoxy and poly? COLD-EH' Fiberglass and Composite Boat Building 9 12-26-2005 06:00 PM
Poly Tanks nassaw Materials 2 02-28-2005 08:29 AM
