method #1
the split mold method-
submarine is made in two seperate peices by molding process, then the two halves joined together on a horizontal axis just as the way a model submarine is made. steel flanges running the circumference of the face surfaces, about 3-4 inches wide and about 1/2 -3/4 inch thick are welded onto the steel rebar protuding from each half mold subs horizontal sides to form flat mating surfaces. these are then bolted down with a gasket of epoxy layered between the two steel flanges. upper and lower. huge bolts are used to secure the two halves. and a watertight gasket is places between these steel face surfaces. so the two halves become one unit. this allows the two halves to be cheaply moved and reassembled or if the sub ever needed to be re-fitted, the bolts can be removed and the sub halved open.
the groove line that is formed at the mating surfaces perimeter outside the hull- which was not covered in cement is then filled with an epoxy/filler. sealing up the whole sub into a pressure vessel.
method 2.
a complete submarine hull is built in ferro-cement - then layered. ie. the shell becomes a mold for itself and three or more layers are built up using the same process of welded mesh and stringers.
advantages of the split mold is cost- since you are not building up layers i.e. you would have 6 inch walls after the pour,- the cost is less. however you then require two truck loads to move both halves to a marina. or other finishing off area near water. but potentially no crane or a small crane could be used. with a hydraulic trailer being the best option and cheapest.
the advantages of the layer ferro-cement method is ease of construction. you have the finished product and it is monocoque. the layers are easy to do yourself. and this is very strong 19 000 -21 000 psi impact resistance. (ref. hartley and brookes) this also allows for ease of transport(assuming both sub methods built to 50 ft loa)since the costs for transport are very large sums dealing with big cranes --rental trucks etc.
there are other advantages and disadvantages, but those are my main ones...
feel free to add your own advantages or disadvantages...
can of worms- opened!
method 2.
