Old 05-22-2009, 11:56 AM
harisankar harisankar is offline
Rep: 10 Posts: 10
Fender Design
Dear All,
I need to design a Fender for a 65 ton bollard pull pusher TUG.
Can somebody help me by suggesting the references or guide lines or something of that sort.
Thanks and best regards
Hari Sankar
Old 05-22-2009, 12:25 PM
eponodyne eponodyne is offline
Rep: 166 Posts: 327
Take a look at Viking and Softloop fendering. They're in the right of it.
Basically it's just sections of old tires sandwiched between steel plates and welded on.
You make Baby Jesus want to drink Scotch out of the cat bowl
Old 05-22-2009, 06:36 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
when you say "design"...do you mean to calculated a rough load/impact then selected a fender to suit said load that will transfer the energy....or,.....do you mean to just draw one up that 'looks' ok, like others on the market?
Old 05-27-2009, 08:37 AM
Rep: 10 Posts: 10
Dear Adhoic,eponodyne
thanks for your replies
By design I mean to be able to under stand the general physics behind the design of fenders.
By Adhocs reply, I now have a direction to look forward to.I dont want to just draw one that just looks okay.
I want to refer to somekind of technical paper and some how make an idea of the impact load and a method to select the fender .That is surely the direction i want to look forward to.
Sorry for the late reply coz i was travelling and did not check emails
Hari Sankar
Old 05-27-2009, 10:12 AM
Naval Architect
Ok, in that case then, a good "basic" assumption is that the vessel (generalising since i don't know anything about the boat nor its duty etc) is to take 0.25g as a load over 1 frame bay. This load must be absorbed by the fender and hence transferred into the hull.
So establish the load and hence the energy and then select a fender, from manufacturers data sheets that satisfies the design intent. It is not difficult, but just requires 'leg work'.
Tube fender for boat Alik Boat Design 2 03-22-2008 04:28 AM
Do-It-Yourself Fender Barnacle Bob Open Discussion: All Things Boats & Boating 34 08-07-2005 08:50 AM
