Old 10-01-2004, 04:12 PM
lucdekeyser lucdekeyser is offline
Rep: 45 Posts: 28
fastest straight line sprinter
To avoid inteference with the very interesting thread on "long-skinny power boats" I started a new but related thread to discuss solutions to a peculiar mission: what would be the best hull to achieve the highest speed also in rough seas and to keep the craft as level as possible WITHOUT taking into account turns. Just a bare straight line sprinting machine. The final speed is more important than the time to reach that speed.
If I start with the specs of a 26 m VSV from the spreadsheet published on the Paragon Mann web site http://www.vsvboats.com/, could there be anything to change to the hull to go faster in a straight line but increase the installed power?
Length overall 26,00m
Length waterline 23,97m
Beam moulded 4,47m
Draught maximum 1,30m
Maximum running displacement 49409kg
Installed Power 2680kW
Speed at 40861kg 48,1kts
Luc
Old 10-02-2004, 06:05 PM
JCFARER JCFARER is offline
Registered
Rep: 10 Posts: 54
Beam moulded 4,47m
Luc
Holy mackerel LUC, you are all over...
I would probably say that Hydrofoils would be something you might consider since it would reduce wetted area and therefore reduce drag which would translate into more speed. Also, there seems to be quite a bit of spray in that picture. Spray increases wetted area too. How efficient is that thing really. Good luck.
Jay
Developed Surfaces???? ChrisGibbs Boat Design 49 03-24-2006 08:38 AM
Where do you draw the line... Steal/Copy/Borrow/Immitate ideas & concepts ErikG Boat Design 21 02-25-2005 03:16 PM
Influence of wind gradient on lifting line nico Sailboats 1 12-04-2004 02:04 PM
