  #31
Old 02-19-2009, 01:20 PM
confused confused is offline
Registered User
Rep: 19 Posts: 155
has this become a drivel thread? it's supposed to be about steam launches.
No thank you
Mike
  #32
Old 02-20-2009, 08:01 AM
apex1
No thank you
Mike
You should grant us permission to grumble about uneducated nappy poopers hijacking your thread.
rasorinc............ thanks.
Regards
Richard
  #33
Old 02-20-2009, 10:50 AM
Registered User
Rep: 19 Posts: 155
right...
  #34
Old 02-20-2009, 12:55 PM
Registered User
Rep: 19 Posts: 155
Haha!! Fight!
  #35
Old 02-20-2009, 01:15 PM
apex1
Haha!! Fight!
Mike, do you fight with Kindergarden Kids?
  #36
Old 02-20-2009, 02:49 PM
Registered User
Rep: 19 Posts: 155
no. I fight with my enemys.
  #37
Old 02-23-2009, 03:38 PM
Registered User
Rep: 19 Posts: 155
Are you still here apex1? If so, I need to ask you a question. Now that this has become a drivel thread ( no thanks to rasorinc) I guess that I have the right to ask your advice on an engine I recently thought of. Since my dad has acquired a welder, I can do a lot of stuff that I wasn't able to do when I didn't have one. Well, I'll get to the point. If I made a cylinder, with a smaller diameter cylinder shaped peice of metal on the end that serves as a combustion chamber. It would be easier to just show you what I'm talking about. I'll give you a rough sketch
Thanks
  #38
Old 02-23-2009, 05:07 PM
apex1
Thanks
Ah.. hello Mike!
First you should excuse, rasorinc was one who fought for your thread, not the one who poisoned it! If you look back some posts youll notice that there are some missing?! Deleted by Admin, due to our intervention.
Your engine describes in principle a engine we did discuss earlier. Replace #s 8 + 9 with Valves and it´ll work. But it should be a very heavy engine as her predecessors had been.
It can be done, no doubt, but my knowledge for example is not sufficient to design it !?!
Regards
Richard
  #39
Old 02-23-2009, 05:20 PM
Registered User
Rep: 19 Posts: 155
good. thanks for your advice man! I have thought for weeks now, and I have realized the only thing that I can build that is HALFWAY legal is a tractor, with that engine that I designed. I have a welder, so I can build a heavy duty metal tractor, and it would be slow and safe and burn anything. I need another answer from you though. (please! ) I need to know how much power a 1 inch bore cylinder running on wvo put out if it is 1 and a half inches long, and had a stroke of 1 inch?
thanks! and when you say replace 7 and 8 with valves, you mean check valves or what type of valves? I think I'll replace the fuel inlet pipe with a tap valve to control the flow of fuel to the engine, so it willl be the throttle. I will also add a decompresser tap to the hot bulb.
  #40
Old 02-23-2009, 05:46 PM
apex1
maybe 1000W, when running on Mc Donalds fuel.
thanks! and when you say replace 7 and 8 with valves, you mean check valves or what type of valves? I mean inlet valves !I think I'll replace the fuel inlet pipe with a tap valve to control the flow of fuel to the engine, so it willl be the throttle. I will also add a decompresser tap to the hot bulb.
You should try to find hot bulb engine drawings through the I-net. Then just scale it down and drive your neighbour mad, by asking him to get it done.
Regards
Richard
  #41
Old 02-23-2009, 05:51 PM
Registered User
Rep: 19 Posts: 155
thanks again!
Ha! I'll drive my neighbor mad with the loud clanking noise made by my engine!
so, about 1.5 hp and alot of torque!
  #42
Old 02-23-2009, 06:24 PM
apex1
thanks again!
They´ll love it, I´m shure.
But Fantail Steam Launch...ähh
  #43
Old 02-23-2009, 06:36 PM
Registered User
Rep: 19 Posts: 155
Yes. I will still build one as soon as I can still, but I "do'nt" have enough money yet I'm "shure", So I will focus on building my burn all liquid tractor. Ahh, yes, it will even burn water! (yes it will! just put water in the fuel tank, and the hot bulb will turn it into steam!)
  #44
Old 02-23-2009, 09:32 PM
apex1
Ja, and in heaven is funfair............
  #45
Old 02-23-2009, 09:39 PM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
Yeh And 66 Virgins Apex1
Cushion of steam juiceclark Hybrid 3 07-27-2008 05:26 PM
steam launches greg simpson Open Discussion: All Things Boats & Boating 39 07-06-2006 12:43 AM
steam engine yipster Powerboats 30 04-19-2005 11:55 AM
Steam Engine emanresu Boat Design 3 01-20-2005 09:51 PM
Looking for Designer - Resotration of wooden launches Archive Services & Employment 1 06-12-2001 03:38 AM
