| Exterior Fiber on Shaft When laying up a tapered shaft, do the shorter lengths of fiber go next to the center of the shaft with the full length fibers near the outside surface? Or do they go near the outside surface with the full length fibers running near the center? Thanks if anyone can give me a quick response. Regards |
| whatever material is in the centre of the shaft does nothing for torsion! |
| Yes that is correct. Perhaps I need to be more precise. The core is corecell. The top of the shaft has a larger dimeter than the bottom of the shaft due to thicker laminates in this area. This means that not all of the 0 degree fibers will be full length. There will be several series of layers that step back toward the fat end. My question is: Do I start with the short fibers and build out the shaft at the top and then progressively go to the full length fibers? Or is it the inverse layup? |
| Hmmm....terminology again. Bottom of shaft??..you mean one end of the shaft, yes?...since there is no "bottom" of a shaft! Well, firstly what does the design dwg say, do you have one?..if not, what is the design for, has this been calculated by you or another? The short fibres, i am assuming in this case, are for merely tapering the shaft or 'filling' out. If this is the case, then the shorter fibres are best underneath the longer fibres. Since the long full length fibres take the strain along the entire length, and these being the outermost fibres. So, think of the shorter ones as being just "gap fillers" to allow you to construct a tapered shaft. Because without the need to taper, there is no 'gap filling' hence the shaft is made entirely of long fibres. If i understand you correctly. |
| I understand your problem, the parallel fibres are on the outside, the tapered ones on the inside.
| Thanks Landlubber and Ad Hoc. I was thinking that the full length fibers shoud be on the outside. However, I had this idea if the shorter fibers were on the outside, the effect would be somewhat like a leaf spring on a car. Will stick them near the center as y'all advised. Thanks again |
| is it a short shaft or long shaft? | donell67 | Outboards | 2 | 03-13-2007 11:07 PM |
| long shaft or short shaft | Bill Kubiak | Powerboats | 17 | 05-26-2006 12:00 PM |
| Exterior fiberglass repair | FishingAaron | Fiberglass and Composite Boat Building | 1 | 06-10-2005 02:28 AM |
| short shaft motor on long shaft boat | ohenry | Boat Design | 0 | 03-21-2005 08:02 PM |
| exterior mutants | potboiler | Powerboats | 6 | 11-10-2001 07:15 AM |
