| Extending a hull? Does anyone have any info on or has done a hull extention ? I have a 21ft fly bridge . glass over ply. want to extend it 4ft. Thanks Matt |
| Matt, You need to give us more information on the boat. Type of power, planing or displacement, type of use intended and speed, pictures etc. You are talking about a radical change, must proceed carefully. One thing in your favor is theat glass over ply will be easy to work with! Don |
| Hi Don. It will have a 225 outboard on a pod bolted to the transom, will do aprox 30 knts, its a fly bridge cruiser mainly for fishing with a v beath up front.and its a planing hull. . Ive searched the net but cant find any info or pic anywhere. Thanks Mate. |
| I've done something similar 2 years ago. Made the extension in a makeshift mold, laminated aluminium L-profile all around the inside edge and bolted the box to the existing transom after applying a layer of marine sealant (Sikaflex). In my case I needed another ft of engine room for 2 Berkeley jets, so I made holes in the old transom where I needed them, left the rest intact. I contemplated laminating directly to the existing hull, but decided not to because I didn't trust the adherence to 25 yrs old laminate, especially the bilge that has been oily for as long as I can remember. Experts told me that it can be done, but the contact area should be 4-5 times the wall thickness. |
| Hi CDK, thanks for the reply. so u build an alloy extention tub and bolted it to the exsisting transom? is that correct? i want to extened my hull for extra fishing space. Matt |
| Replace "alloy' with "GRP" and you've got the picture. |
| cdk why would you want 2 jet drives? -jim lee |
| Sweet. i also want to make a pod that will double not only as a outboard mount but a deck extention 1mt long as i want to cut the transom out and extend to the floor thur to the new transom. Was thinking about making it in aluminum for extra strenght. Matt |
| CLP; mono-hull vs multi-hull | jibbernaught | Boat Design | 0 | 06-05-2007 03:07 PM |
| differences between nitro hull and vee pad hull | riveramunizaga | Boat Design | 4 | 05-24-2005 10:27 PM |
| what is faster a flat boat hull or a vee pad hull | riveramunizaga | Boat Design | 24 | 05-24-2005 02:18 PM |
| hull boat redesigns (hull pad project) | riveramunizaga | Boat Design | 9 | 05-12-2005 08:35 PM |
| Hull or hull & deck broke apart during 40-50 mph turn | Jeff | Powerboats | 1 | 07-09-2002 12:27 AM |
