Old 11-01-2005, 04:29 AM
Alik's Avatar
Alik Alik is online now
Rep: 1020 Posts: 1,893
Exhaust of FRP
Need info on exhaust design of FRP. Specially interested in suitable materials. We're going to have ones for 280h.p. diesels, Please, share Your experience.
Old 11-01-2005, 05:34 AM
nemo nemo is offline
Naval Architect
Rep: 137 Posts: 132
As far as I know, phenolic resins are suitable for exhausts, because those resins are the best ones for high temperatures (around 160°C).
If interested, I can post some pictures of large frp exhausts (1000 HP).
"water always knows better"
Old 11-01-2005, 06:27 AM
Alik's Avatar
Interested!
Old 11-01-2005, 06:55 AM
Naval Architect
Rep: 137 Posts: 132
Hi,
Hope these pictures can inspire you. You can see exhaust pipe with low speed and high speed pipes. They have been laminated with phenolic resins. You can also see waterjet ducts. They have been laminated together with the hull, on a 4 pieces plug.
Old 11-01-2005, 08:59 AM
Alik's Avatar
Thanks, Nemo!
Old 11-02-2005, 02:19 PM
JORGE LANG JORGE LANG is offline
Rep: 60 Posts: 21
When we design an exhaust system where FRP tubing will be required, this is what we use. The exhaust should never approach temperatures of 160c, but we know what debris can do to a water intake. Also, we only use silicon hose connections that also have the same temperature rating. I hope this helps.
JORGE LANG
DEANGELO MARINE EXHAUST
Old 11-02-2005, 03:52 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
I will bite. Why or what is the big advantage?
Old 11-02-2005, 04:23 PM
Rep: 60 Posts: 21
Besides building exhaust systems for major O.E.M. builders, we do a lot of replacement systems. In some cases we see frp tubing or mufflers that have overheated. The source of the excessive heat in the exhaust after it has been cooled by the raw water could be many things, obstruction to the water going to the exhaust mixer tank, clogged diffuser, or a system not designed for a specific engine and/or application. By using a higher rated frp resin and silicon hose, adds a little insurance against damage. Considering the differeance in price, it's well worth the protection.
JORGE LANG
Old 11-02-2005, 09:26 PM
Walaa Walaa is offline
FRP Exhaust
My company (Centek Industries - USA) is a specialist in FRP exhaust system components. In fact, that is all we do. We use a high temperature polyester resin good to 350 F. You can get more information at our web-site at www.centekindustries.com
Feel free to contact me for more information.
Walaa
Mercruiser exhaust cptmclark Propulsion 0 07-31-2005 10:19 PM
engine exhaust question - sailboat diesel fdubois Sailboats 9 05-28-2005 06:31 AM
Sterndrive - corrosive exhaust? Guest Propulsion 11 05-03-2005 10:02 AM
Wraping exhaust hose? PowerTech Powerboats 0 03-07-2005 08:47 PM
exhaust material question Mr_Boat Materials 2 08-21-2004 12:02 AM
